IPv6 networks are connected by IPv6 routers. IPv6 routers pass IPv6 packets from one network segment to another.
The IPv6 Routing configuration screen displays.
                                         RA Convert (milliseconds)  |
                                         Select this option to convert multicast router advertisements (RA) to unicast router advertisements at the dot11 layer. Unicast addresses identify a single network interface, whereas a multicast address is used by multiple hosts. This setting is disabled by default.  |
                                         Throttle  |
                                         Select this option to throttle RAs before converting to unicast. Once enabled, set the throttle interval and maximum number of RAs. This setting is disabled by default.  |
                                         Throttle Interval (milliseconds)  |
                                         Enable this setting to define the throttle interval (3 - 1,800 seconds). The default setting is 3 seconds.  |
                                         Max RAs  |
                                         Enable this setting to define the maximum number of router advertisements per router (1 - 256) during the throttle interval. The default setting is 1.  |
The IPv6 static route Add Row screen displays.
                                         Network Address  |
                                         Set the IPv6 network address. Other than the length and slightly different look versus an IPv4 address, the IPv6 address concept is same as IPv4.  |
                                         Gateway  |
                                         Set the IPv6 route gateway. A network gateway in IPv6 is the same as in IPv4. A gateway address designates how traffic is routed out of the current subnet.  |
                                         Interface  |
                                         If using a link local address, set the VLAN (1 - 4,094) used a virtual routing interface for the local address.  |
Select Reset to revert to the last saved configuration.
