Device Image Management
Using maintenance mode, you can download
firmware on one or more devices in the IP fabric with minimal disruption to data path
traffic. Both Clos and non-Clos fabrics are supported. The maintenance mode feature is
supported only on SLX devices running SLXOS 20.1.1 and later.
EFA supports the following firmware download features.
- Firmware download with maintenance mode
supporting the following:
- Asynchronously launched
operations
- Sanity and pre-install script
verification
- Set convergence timeout,
enable, and disable
- Persisting the running
configuration so that running configuration and maintenance mode
configuration are preserved after reboot
- Firmware download with the
no
commit
option to enable restoration of firmware to a previous
version
- Firmware host registration, with support for register, update, delete, and list
operations
- Firmware download preparation, with support for add, remove, and list operations
show
option, to display a table of devices in the fabric and
their corresponding status
- The device firmware must be SLX-OS 20.1.1 or
later to support firmware download with maintenance mode for a hitless firmware
upgrade.
- This feature assumes an existing host that
contains SLX-OS firmware images ready to be downloaded.
- You can use this feature on a device where
EFA TPVM is deployed, as long as you follow the instructions in Upgrade Device Firmware in a High Availability Deployment.
- If you downgrade software from version 20.1.2a to 20.1.1, you must manually
remove certificates.
Supported devices
The SLX-OS firmware download with maintenance mode is supported on the following SLX devices
running SLX-OS 20.1.1 and later.
- SLX 9540
- SLX 9640
- SLX 9150-48Y
- SLX 9150-48XT
- SLX 9250
- SLX 9740
