You can add and delete local IP address configurations during the following operations:
The Local IP address is configured on the VE interface assigned to a particular tenant network. You can select different local IP addresses for each device in a tenant network.
efa tenant epg create --name ten1epg1 --tenant tenant1 --vrf red
--switchport-mode trunk --ctag-range 11 --anycast-ip 11:10.10.11.1/24
--port 10.24.80.150[0/1],10.24.80.151[0/1]
--local-ip 11,10.24.80.150:11.22.33.41/24 --local-ip 11,10.24.80.151:11.22.34.41/24
efa tenant epg show
Tenant: tenant1
Description:
Type: extension
Ports : 10.24.80.151[0/1]
: 10.24.80.150[0/1]
Port Property : switchport mode : trunk
: native-vlan-tagging : false
NW Policy: ctag-range :11
: vrf : red
: vrf-State : vrf-device-created
: vrf-Device-State : provisioned
: vrf-App-State : cfg-refreshed
: l3-vni : 8190
Network Property [Flags : * - Native Vlan]
| Ctag | L2-Vni | Anycast-IPv4 | Anycast-IPv6 | BD-name | Local IP (Device-IP->Local-IP) | Dev-state | App-state |
| 11 | 11 |10.10.11.1/24 | | | 10.24.80.151->11.22.34.41/24 | provisioned | cfg-refreshed |
| | | | | | 10.24.80.150->11.22.33.41/24 | | |
efa tenant epg update --name epgv20 --tenant tenant1 --operation
local-ip-delete --local-ip 11,10.24.80.150:11.22.33.41/24
efa tenant epg show
Tenant : t3
Description :
Type : l3-hand-off
Ports : 10.20.50.209[0/27]
POs : posv9
NW Policy : ctag-range : 201-202
: vrf : vrfv20
: l3-vni : 5110
| 201 | 201 | | | | 10.20.50.209->44.4.4.5/24 | provisioned | cfg-in-sync |
| | | | | | 4444:44::5/120 | | |
| | | | | | 10.20.50.208->44.4.4.4/24 | | |
| | | | | | 4444:44::4/120 | | |
| 202 | 202 | | | | 10.20.50.209->44.4.5.5/24 | provisioned | cg-in-sync |
| | | | | | 4444:45::5/120 | | |
For 'unstable' entities, run 'efa tenant po/vrf show' for details
efa tenant epg update --name ten1epg1 --tenant tenant1
--operation local-ip-add --local-ip 11,10.24.80.150:11.22.33.41/24
efa tenant epg show
Tenant: tenant1
Description:
Type: extension
: 10.24.80.150[0/1]
: vrf : red
: l3-vni : 8190
| 11 | 11 | | | | 10.24.80.151->11.22.34.41/24 | provisioned | cfg-in-sync |
