| Symptom | Condition | Workaround |
| EPG create fails with VNI resource not being available in the fabric. | Execute EPG create, delete, and re-create CLI in quick
succession:
Provide a wait of 30 seconds between the create and delete CLI on the same EPG. |
| EPG update "vrf-add" operation fails with the reason as VRF to be added has conflicting VRF on the switch. | Execute EPG update "vrf-add", "vrf-delete", and "vrf-add"
operation CLI in quick succession:
Wait of 30 seconds between the EPG update vrf-add and vrf-delete operations on the same EPG. |
| When VRF is added and deleted to/from and Endpoint Group, in
quick succession, multiple times, events received from inventory
service can get interleaved with the commands. This causes EFA command execution path to find database entries that are yet to be deleted due to previous command run. |
Issue is observed when vrf-add and vrf-delete operation is executed multiple times on Endpoint Group in quick succession. | Wait for a few minutes before executing the vrf-add again on Endpoint Group. |
| If the router-id is changed on the device (add/delete/modified), the device table router-ip field will not change after you do inventory device update. | It's found that inventory did detect the diff and generate the RouterBgpUpdatedMsg to Tenant. Tenant did not handle this message. | Add hook in the RouterBgpUpdatedMsg on tenant handler to set the RouterIP, so that the Tenant DB will have the same value with the device after update. |
| REST opertations aren't retried (as applicable) during the service boot up. | The status aren't set for all the REST operations AFTER publishing all the necessary events on the message bus. | For all the REST operations, set the status AFTER publishing all the necessary events on the message bus. |
