EFA does not provision
reload-delay 90
configuration on Cluster Edge Port (CEP) interfaces. EFA instead provisions cluster-track configuration
on CEP interfaces when the CEP is configured as a member of an EPG (endpoint group)
during the creation or updating of endpoint groups.
During upgrade from EFA
2.2.0 to 2.3.0, EFA
marks all the CEPs with the intended cluster-track configuration
and shows it as configuration drift. On reconciliation of the drift, EFA pushes the cluster-track configuration
to the CEP ports. Before the cluster-track configuration push, EFA automatically removes the
reload-delay
configuration from the CEP ports.
# efa tenant po create --name po11 --tenant tenant1 –speed 10Gbps --negotiation active --port 10.24.80.134[0/15] => CEP # efa tenant po create --name po12 -–tenant tenant1 -–speed 10Gbps --negotiation active -–port 10.24.80.134[0/25],10.24.80.135[0/25] => CCEP # efa tenant epg create --name ten1epg1 --tenant tenant1 --switchport-mode trunk --ctag-range 1001 --port 10.24.80.134[0/35] --po po11,po12
