Display EFA Running Configurations
You can view the running-config of all current EFA configurations for core services.
The output is displayed in the following order: Asset, Fabric, Tenant commands. The command output contains the default values for each configuration line item.
You can use the command output for CLI playback on an empty EFA deployment, which is a useful tool for recovery.
The output of efa show-running-config command is also captured as part of the supportsave zip file.
Run the efa show-running-config command.
$ efa show-running-config
efa inventory device register --ip "10.24.80.191" --username admin --password password
efa inventory device setting update --ip "10.24.80.191" --maint-mode-enable-on-reboot  No
--maint-mode-enable No --health-check-enable No --health-check-interval 6m
--health-check-heartbeat-miss-threshold 2 --config-backup-periodic-enable Yes
--config-backup-interval 24h --number-of-config-backups 4
efa inventory device register --ip "10.24.80.192" --username admin --password password
efa inventory device setting update --ip "10.24.80.192" --maint-mode-enable-on-reboot  No
efa fabric create --name "default" --type clos --stage 3 --description "Default Fabric"
This example shows only a partial list of typical output.
