A non-Clos fabric is used in small data centers.
efa fabric create
efa fabric device add
A device must be registered with Inventory Service before you can add it to a fabric. However, if you provide a user name and password when you run the command, then the devices are automatically registered with the Inventory Service. See the examples at the end of this procedure.
efa fabric device
add-bulk command. If you choose to add multiple devices in
bulk, ensure you perform the following operations first:$ efa fabric configure
Tip
The validation process reports any errors as a response to the efa fabric device add or efa fabric configure operations. You can use the efa fabric error show command to export these errors to a CSV file.$ efa fabric create --name extr-fabric --type non-clos
efa fabric device add --name extr-fabric --ip 10.x.x.x --rack room1-rack1 --username admin --password password
$ efa fabric device add-bulk --name extr-fabric --rack room1-rack1 --ip 10.24.80.134,10.24.80.135 --rack room1-rack2 --ip 10.25.225.163,10.25.225.167
efa fabric configure --name extr-fabric
