Configure “description” per EFA port-channel which gets configured on SLX
                port-channel. The default value of po “description” is “EFA Port-channel
                    <efa-po-name>”. You can configure PO “description” during po
                    create and po update operations.
When you upgrade from EFA 2.3.2 to EFA 2.4.0 or EFA 2.5.0, all the POs contains the default “description” and is displayed as part of efa tenant po show --detail.
efa tenant po create --name <po-name> --tenant <tenant-name> --description <po-description>
               --speed <100Mbps|1Gbps|10Gbps|25Gbps|40Gbps|100Gbps> --negotiation <active|passive|static>
	--port <list-of-po-members> --min-link-count <min-link-count> --number <po-number> --lacp-timeout <short|long>
                efa tenant po update --name <po-name> --tenant <tenant-name>
              --operation <port-add|port-delete|lacp-timeout|description|min-link-count>
              --port <list-of-po-members> --lacp-timeout string <short|long> --min-link-count <min-link-count>
efa tenant po create --name ten1po1 --tenant ten1 --port 10.20.246.15[0/1],10.20.246.16[0/1] --speed 10Gbps --negotiation active --description tenant1po1 efa tenant po create --name ten1po2 --tenant ten1 --port 10.20.246.15[0/2],10.20.246.16[0/2] --speed 10Gbps --negotiation active efa tenant po update --name ten1po1 --tenant ten1 --operation description --description tenat1po1changed
Tenant          : ten1
Description     : tenat1po1changed
Speed           : 10Gbps
Negotiation     : active
Min Link Count  : 1
Lacp Timeout    : long
Ports           : 10.20.246.15[0/1]
                : 10.20.246.16[0/1]
State           : po-created
Dev State       : provisioned
App State       : cfg-in-sync
Tenant          : ten1
Description     : EFA Port-channel ten1po2
Speed           : 10Gbps
Min Link Count  : 1
Lacp Timeout    : long
Ports           : 10.20.246.15[0/2]
                : 10.20.246.16[0/2]
State           : po-created
