Day-0 operations consist of forming the fabric.
This table provides examples of the commands that you use to create a small data center (non-Clos) fabric with two SLX devices. For more information about commands and supported parameters, see Extreme Fabric Automation Command Reference, 2.5.0 .
| Operation | Command Example |
| Create a fabric | efa fabric create --name CNCF type non-clos |
| Select MCT ports | efa fabric setting update --rack-ld-mct-ports '0/29,0/30,0/31,0/32' --name
								CNCF |
| Enable backup routing | efa fabric setting update --backup-routing-enable Yes --name
							CNCF |
| Disable VLAN VNI auto-map | efa fabric setting update --vni-auto-map No --name CNCF |
| Add the first device | efa fabric device add --ip 10.24.80.158 --hostname slx-a --rack pod1 --username
								admin --password password --name CNCF |
| Add the second device | efa fabric device add --ip 10.24.80.159 --hostname slx-b --rack pod1 --username
| Configure the fabric | efa fabric configure --name CNCF |
