Use the EFA CLI to add and delete management sub-interfaces.
efa mgmt subinterface create --name <name> --ip-address <IP Subnet> --vlan-id <VLAN>
efa mgmt subinterface delete --name <name>
If a management network with the name exists, it is deleted. Otherwise, the correct response is provided in the command output.
For more information about the commands, see the Extreme Fabric Automation Command Reference, 2.5.0 .
Examples:
$ efa mgmt subinterface? Management subinterface commands Usage: efa mgmt subinterface [command] Available Commands: create Create sub-interface (sub-interface) delete Delete sub-interface (sub-interface) show List of sub-interfaces (sub-interfaces) Flags: -h, --help help for sub-interface Use "efa mgmt subinterface [command] --help" for more information about a command.
$ efa mgmt subinterface create -h
Create management subinterface (sub-interface)
Usage:
efa mgmt subinterface create [flags]
Flags:
--name string Name of the sub-interface
--vlan-id int VLAN Id of sub-interface
--ip-address string IP Address of sub-interface including subnet mask.
Example: 10.24.80.150/24
-h, --help help for create
$ efa subinterface delete -h
Delete management subinterface (sub-interface)
Usage:
efa mgmt subinterface delete [flags]
Flags:
-h, --help help for delete
$ efa mgmt subinterface show -h
List of management sub-interfaces (sub-interfaces)
Usage:
efa mgmt subinterface show [flags]
Flags:
-h, --help help for show
$ efa mgmt subinterface create --name server1 --vlan-id 20 --ip-address
20.20.20.2/24
Subinterface server1 created successfully
$ efa mgmt subinterface delete --name server1 Subinterface server1 deleted successfully
$ efa mgmt subinterface show +---------------+------------------+------+---------------+ | Sub-Interface | Parent Interface | Vlan | IP Subnet | +---------------+------------------+------+---------------+ | server1 | eth0 | 20 | 20.20.20.2/24 | +---------------+------------------+------+---------------+ | server2 | eth0 | 50 | 50.50.50.2/24 | +---------------+------------------+------+---------------+ Management Subinterfaces Details
$ efa mgmt subinterface show --name server1 +---------------+------------------+------+---------------+ | Sub-Interface | Parent Interface | Vlan | IP Subnet | +---------------+------------------+------+---------------+ | server1 | eth0 | 20 | 20.20.20.2/24 | +---------------+------------------+------+---------------+ Management Subinterface Details
