efa fabric show --name fabric1
Fabric Name: fabric1, Fabric Description: , Fabric Type: non-clos
|  IP ADDRESS  | RACK  | HOST NAME |    ASN     | ROLE | DEVICE STATE |  APP STATE  | CONFIG GEN REASON | PENDING CONFIGS | VTLB ID | LB ID |
| 10.20.246.15 | rack1 | SLX       | 4200000000 | leaf | provisioned  | cfg in-sync | NA                | NA              | 2       | 1     |
| 10.20.246.16 | rack1 | SLX       | 4200000000 | leaf | provisioned  | cfg in-sync | NA                | NA              | 2       | 1     |
efa fabric setting show --name fabric1 --advanced | grep -i "backup routing“
| Backup Routing Enable          | Yes                    |
| Backup Routing IPv4 Range      | 10.40.40.0/24          |
| Backup Routing IPv6 Range      | fd40:4040:4040:1::/120 |
efa tenant show
| Name |  Type   | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD |        Ports         |
| ten1 | private |   11-20    |             |             |    10     |   false   | 10.20.246.16[0/1-10] |
|      |         |            |             |             |           |           | 10.20.246.15[0/1-10] |
efa tenant vrf show
|   Name   | Tenant | Routing Type | Centralized Routers | Redistribute | Max Path | Local Asn | Enable GR |       State        |  Dev State  |  App State  |
| ten1vrf1 |  ten1  | distributed  |                     |  connected   |    8     |   5000    |   false   | vrf-device-created | provisioned | cfg-in-sync |
efa tenant epg show –detail
Tenant        : ten1
Type          : extension
State         :
Ports         : 10.20.246.15[0/1]
POs           :
Port Property : SwitchPort Mode     : trunk
              : Native Vlan Tagging : false
NW Policy     : Ctag Range          : 11
              : VRF                 : ten1vrf1
              : L3Vni               : 8192
| Ctag |          Ctag           | L2Vni | BD Name | Anycast IPv4 | Anycast IPv6 |       Local IP        | IPv6 ND |    IPv6 ND     |   IPv6 ND    |  Dev State  |  App State  |
|      |       Description       |       |         |              |              | [Device-IP->Local-IP] |   Mtu   | Managed Config | Other Config |             |             |
|  11  | Tenant L3 Extended VLAN |  11   |         | 10.0.11.1/24 |              |                       |         |     false      |    false     | provisioned | cfg-in-sync |
                                        L1# show running-config bridge-domain 4095 bridge-domain 4095 p2mp description Tenant L3 Extended BR BD pw-profile Tenant-profile router-interface Ve 8191 ! L1# show running-config interface Ve 8191 interface Ve 8191 vrf forwarding ten1vrf1 ip address 10.40.40.252/31 ipv6 address fd40:4040:4040:1::fe/127 no shutdown ! L1# do show running-config router bgp router bgp local-as 4200000000 capability as4-enable fast-external-fallover neighbor 10.20.20.3 remote-as 4200000000 neighbor 10.20.20.3 next-hop-self address-family ipv4 unicast network 172.31.254.203/32 network 172.31.254.226/32 maximum-paths 8 graceful-restart ! address-family ipv4 unicast vrf ten1vrf1 local-as 5000 redistribute connected neighbor 10.40.40.253 remote-as 5000 neighbor 10.40.40.253 next-hop-self maximum-paths 8 ! address-family ipv6 unicast vrf ten1vrf1 redistribute connected neighbor fd40:4040:4040:1::ff remote-as 5000 neighbor fd40:4040:4040:1::ff next-hop-self neighbor fd40:4040:4040:1::ff activate maximum-paths 8 ! !  |
