Backup Routing
            - EFA automates the backup routing
                configuration among the MCT nodes by configuring ipv4 or ipv6 IBGP neighborship
                between the MCT nodes.
            - When the local-asn for a VRF (used in
                an endpoint group) is updated using the local-asn-add operation, the remote-asn of
                the backup routing IPv4 or IPv6 IBGP neighbors also gets updated.
            - When the remote-asn of an existing
                backup routing BGP neighbor is updated, the corresponding BGP session is reset using
                    clear ip bgp neighbor
                    <neighbor-ip> vrf <tenant-vrf-name>, which lead to traffic
                disruption till the session is up.
                an endpoint group) is deleted using local-asn-delete operation, the remote-asn of
                the backup routing IPv4 or IPv6 IBGP neighbors also gets updated to the local-asn
                configured at the global router bgp level followed by the backup routing bgp session
                reset.
        BGP neighbors (established with the EFA managed fabric devices and established by the
            devices not managed by EFA) must modify their remote-asn based on the modified
            local-asn.
