Configuration Supporting Multiple Management
        IP Networks
This work flow highlights the changes
        that occur in your system when you configure Multiple Management IP (MMIP)
        networks.
        Day 0 and Installation
                Configuration
                - In a multi-node deployment, the
                    VIP (virtual IP address) that you enter during installation is the same as for a
                    non-MMIP deployment. This VIP is distinguished from those added during MMIP
                    network operations and cannot be deleted.
                - During installation, you are
                    prompted to create additional MMIP networks and routes.
                - Keepalived, ingress, and
                    interface changes are performed on both nodes of a multi-node deployment.
                - Configuration is persisted for
                    RMA purposes, so that the Supportsave function has data for debugging
                    issues.
            For step-by-step instructions for configuring MMIP during installation or upgrade,
                see the
    Extreme Fabric Automation Deployment Guide,
     2.5.0
        Day 1 to Day n Configuration
                - You can use the EFA CLI or REST
                    APIs to add and delete management routes and IP address and VLAN
                    combinations.
                - Configuration is persisted for RMA purposes, so that the Supportsave function
                    has data for debugging issues.
                - The backup and restore process
                    also restores the previous configuration of the sub-interfaces.
