In a multi-node deployment, you can add,
		delete, and show management routes for Multiple Management IP (MMIP) networks.
		Typically, the create and delete
			operations do not cause a high-availability failover. The route is instantiated on the
			active node of the cluster. If failover does occur from node 1 to node 2, then
			keepalived ensures that the route transitions from node 1 to node 2.
				To add a management route, run
					the following command.
					$ efa mgmt route create --src <mmip-vip> --to <dest-cidr> --via <next-hop-ip>
				If a route with the same destination exists, the operation fails. This
					operation updates the keepalived configuration file on both nodes of the
					high-availability cluster.
				To delete a management route,
					run the following command.
					$ efa mgmt route delete --src <mmip-vip> --to <dest-cidr> --via <next-hop-ip>
				 If a route matching the three parameters does not existing, the
					operation fails. If a matching route is found, the keepalived configuration file
					is updated and reloaded on both nodes of the high-availability cluster.
				To generate a list of all management routes, run the following command.
					$ efa mgmt route show
|  Route-Src  |     Route-To     |  Route-Via  |
| 10.21.30.40 | 192.168.100.0/24 | 10.21.30.41 |
