Provide an option to enable or disable suppress-arp or nd (supress address resolution protocol or neighbor discovery) at the tenant network level so that you can choose to enable suppress-arp or nd per tenant network.
This option is mainly useful for a single rack small data center deployment where the suppress-arp or nd configuration on tenant network is not needed.
efa tenant epg create --name <epg-name> --tenant <tenant-name>
                 --port <port-list> --switchport-mode <trunk|access> --ctag-range <ctag-range>
                 --anycast-ip <ctag:anycast-ipv4> --anycast-ipv6 <ctag:anycast-ipv6> --vrf ten1vrf1
                 --suppress-arp <ctag:true|false> --suppress-nd <ctag:true|false>
 efa tenant epg update --name <epg-name> --tenant <tenant-name> --operation vrf-add
efa tenant epg update --name <epg-name> --tenant <tenant-name> --operation ctag-range-add
                 --ctag-range <ctag-range> --anycast-ip <ctag:anycast-ipv4> --anycast-ipv6 <ctag:anycast-ipv6>
 efa tenant epg update --name <epg-name> --tenant <tenant-name> --operation anycast-ip-add
                    efa fabric show --name fabric1
Fabric Name: fabric1, Fabric Description: , Fabric Type: non-clos
|  IP ADDRESS  | RACK  | HOST NAME |    ASN     | ROLE | DEVICE STATE |  APP STATE  | CONFIG GEN REASON | PENDING CONFIGS | VTLB ID | LB ID |
| 10.20.246.15 | rack1 | SLX       | 4200000000 | leaf | provisioned  | cfg in-sync | NA                | NA              | 2       | 1     |
| 10.20.246.16 | rack1 | SLX       | 4200000000 | leaf | provisioned  | cfg in-sync | NA                | NA              | 2       | 1     |
efa tenant show
| Name |  Type   | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD |         Ports         |
| ten1 | private |   11-20    |             |             |    10     |   false   | 10.20.246.15[0/1-10]  |
|      |         |            |             |             |           |           | 10.20.246.16[0/1-10]  |
| ten2 | private |   21-30    |             |             |    10     |   true    | 10.20.246.15[0/11-20] |
|      |         |            |             |             |           |           | 10.20.246.16[0/11-20] |
efa tenant vrf show
|   Name   | Tenant | Routing Type | Centralized Routers | Redistribute | Max Path | Local Asn | Enable GR |       State        |  Dev State  |  App State  |
| ten1vrf1 |  ten1  | distributed  |                     |  connected   |    8     |           |   false   | vrf-device-created | provisioned | cfg-in-sync |
| ten2vrf1 |  ten2  | distributed  |                     |  connected   |    8     |           |   false   | vrf-device-created | provisioned | cfg-in-sync |
efa tenant epg create --name ten1epg1 --tenant ten1 --port 10.20.246.15[0/1],10.20.246.16[0/1]
           --switchport-mode trunk --ctag-range 11-12
           --anycast-ip 11:10.0.11.1/24 --anycast-ip 12:10.0.12.1/24 --anycast-ipv6 11:11::1/127 --anycast-ipv6 12:12::1/127 --vrf ten1vrf1
           --suppress-arp 11:false –suppress-nd 12:false
efa tenant epg create --name ten2epg1 --tenant ten2 --port 10.20.246.15[0/11],10.20.246.16[0/11]
           --switchport-mode trunk --ctag-range 21-22
           --anycast-ip 21:10.0.21.1/24 --anycast-ipv6 21:21::1/127 --anycast-ip 22:10.0.22.1/24 --anycast-ipv6 22:22::1/127 --vrf ten2vrf1
           --suppress-arp 21:false –suppress-nd 22:false
efa tenant epg show –detail
Tenant        : ten1
Type     : extension
State         :
Description   :
Ports         : 10.20.246.15[0/1]
              : 10.20.246.16[0/1]
POs           :
Port Property : SwitchPort Mode     : trunk
              : Native Vlan Tagging : false
NW Policy     : Ctag Range          : 11-12
              : VRF            : ten1vrf1
              : L3Vni               : 8192
| Ctag |          Ctag           | L2Vni | BD Name | Anycast IPv4 | Anycast IPv6 |Suppress|        Local IP      | IPv6 ND |    IPv6 ND     |   IPv6 ND    |  Dev State  |  App State  |
|      |       Description       |       |         |              |              | ARP/ND |[Device-IP->Local-IP] |   Mtu   | Managed Config | Other Config |             |             |
|  11  | Tenant L3 Extended VLAN |  11   |         | 10.0.11.1/24 |  11::1/127   |  F/T        |                      |         |     false      |    false     | provisioned | cfg-in-sync |
|  12  | Tenant L3 Extended VLAN |  12   |         | 10.0.12.1/24 |  12::1/127   |  T/F        |                      |         |     false      |    false     | provisioned | cfg-in-sync |
Tenant        : ten2
Type     : extension
State         :
Description   :
Ports         : 10.20.246.15[0/11]
              : 10.20.246.16[0/11]
POs           :
NW Policy     : Ctag Range          : 21-22
              : VRF            : ten2vrf1
              : L3Vni               : 8191
| Ctag |          Ctag         | L2Vni | BD Name      | Anycast IPv4 | Anycast IPv6 |Suppress|        Local IP      | IPv6 ND |    IPv6 ND     |   IPv6 ND    |  Dev State  |  App State|
|  21  | Tenant L3 Extended BD | 4097  | Auto-BD-4097 | 10.0.21.1/24 |  21::1/127   | F/T         |                      |         |     false      |    false     | provisioned |cfg-in-sync|
|  22  | Tenant L3 Extended BD | 4098  | Auto-BD-4098 | 10.0.22.1/24 |  22::1/127   | T/F         |                      |         |     false      |    false     | provisioned |cfg-in-sync|
