  EFA can recover in-flight (in-progress)
		transactions after a service restart or high-availability failover.
			After a service restart or high-availability failover, EFA can recover in-flight transactions
				by rolling them back or rolling them forward. In-flight transactions are those that
				are outstanding in the execution log after a restart or a failover.
					- When transactions are rolled
						back, the requested action is undone.
						forward, the requested action is completed.
			By default, this feature enables the automatic recovery of Day-1 through Dan-N operations for
				tenant-related configurations. You can use the
efa system feature update
					--inflight-transaction-auto-recovery disable command to disable the
				feature. When the feature is enabled, the recovery strategy is as follows.
Table 1. Recovery strategy
								| Operation type |
								Commands |
								Strategy |
								| Create operations |
										- efa
												tenant create
										- efa
												tenant epg create
										- efa
												tenant po create
										- efa
												tenant service bgp peer create
										- efa
												tenant service bgp peer-group create
										- efa
												tenant vrf create
								Roll back |
								| Delete operations |
										- efa
												tenant delete
										- efa
												tenant epg delete
										- efa
												tenant po delete
										- efa
												tenant service bgp peer delete
										- efa
												tenant service bgp peer-group delete
										- efa
												tenant vrf delete
								Roll forward |
								| Update with add operations, such as port-add, ctag-range-add,
									and vrf-add |
										- efa
												tenant update
										- efa
												tenant epg update
										- efa
												tenant po update
										- efa
												tenant service bgp peer update
										- efa
												tenant service bgp peer-group update
										- efa
												tenant vrf update
								Roll back |
								| Update with delete operations, such as port-delete,
									vrf-delete, and ctag-range-delete |
										- efa
												tenant update
										- efa
												tenant epg update
										- efa
												tenant po update
										- efa
										- efa
										- efa
												tenant vrf update
								Roll forward |
			Consider the following expected behaviors for this feature:
					- During operations that take a long time,
						such as drift and reconcile and firmware downloads, tenant operations and
						recovery operations are blocked.
					- When multiple transactions
						are pending in the execution log after a restart or a failover, recovery
						occurs in the order in which the operations appear in the execution
						log.
					- If a service restart or high availability
						failover occurs during transaction recovery, then the status of those
						recovery operations is changed to a normal status. For example, if a restart
						occurs during the rollback of an endpoint group (EPG), the status changes to
						delete-pending. There is no automatic recovery of interrupted recovery
						transactions. You must manually verify and address the status of such
						operations.
Important
				Day-0 and administrative operations (those for the Inventory Service and Fabric Service) are
					not recovered automatically. If these operations are interrupted by a service
					restart or a failover, you must manually redo the operations.
			This example enables automatic in-flight transaction recovery.
			efa system feature update --inflight-transaction-auto-recovery enable
Feature Setting Updated Successful
--- Time Elapsed: 634.557118ms ---
			This example disables automatic in-flight transaction recovery.
			efa system feature update --inflight-transaction-auto-recovery disable
--- Time Elapsed: 634.557125ms ---
