| Symptom | Condition | Workaround |
| Endpoint group (EPG) create fails with VNI resource not being available in the fabric. | Run EPG create, delete, and re-create CLI in quick succession:
                            Provide a wait of 30 seconds between the create and delete CLI on the same EPG. |
| Endpoint group (EPG) update vrf-add operation fails with the reason as VRF to be added has conflicting VRF on the switch. | Run EPG update vrf-add,
                                    vrf-delete, and vrf-add
                                operation CLI in quick succession:
                            Wait of 30 seconds between the EPG update vrf-add and vrf-delete operations on the same EPG. |
| When VRF is added and deleted to or from and Endpoint Group, in
                                quick succession, multiple times, events received from inventory
                                service can get interleaved with the commands. This causes EFA command execution path to find database entries that are yet to be deleted due to previous command run.  |
                            Issue is observed when vrf-add and vrf-delete operations are run multiple times on Endpoint Group in quick succession. | Wait for a few minutes before running the vrf-add again on Endpoint Group. |
| If the router-id is changed on the device (add, delete, or modified), the device table router-ip field does not change after you do inventory device update. | It is found that inventory did detect the diff and generate the RouterBgpUpdatedMsg to Tenant. Tenant did not handle this message. | Add hook in the RouterBgpUpdatedMsg on tenant handler to set the RouterIP. This enables the tenant DB to have the same value with the device after update. |
| REST opertations are not retried (as applicable) during the service boot up. | The status are not set for all the REST operations AFTER publishing all the necessary events on the message bus. | For all the REST operations, set the status AFTER publishing all the necessary events on the message bus. |
