efa tenant vrf create --tenant "ten1" --name "ten1vrf1" --routing-type "distributed" --rt-type import --rt 100:100 --rt-type export --rt 100:100 --rt-type import --rt 200:200 --rt-type export --rt 200:200 --rt-type import --rt 300:300 --rt-type export --rt 400:400 --max-path 8 --redistribute connected efa tenant vrf create --tenant "ten2" --name "ten2vrf1" --routing-type "distributed" --rt-type import --rt 100:100 --rt-type export --rt 100:100 --rt-type import --rt 200:200 --rt-type export --rt 200:200 --rt-type import --rt 300:300 --rt-type export --rt 400:400 --max-path 8 --redistribute connected VRF Creation Failed: Route Target must be unique. Conflicting value: 'import 100:100'
If you are running EFA 2.5.0 or above, verify the switch configuration on SLX.
                                L1# show running-config vrf bvrf ten1vrf1 rd 172.31.254.69:1 evpn irb ve 8192 address-family ipv4 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ! address-family ipv6 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ! ! vrf ten2vrf1 rd 172.31.254.69:2 evpn irb ve 8190 address-family ipv4 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ! address-family ipv6 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ! !  |
                                L2# show running-config vrf bvrf ten1vrf1 rd 172.31.254.70:1 evpn irb ve 8192 address-family ipv4 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ! address-family ipv6 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ! ! vrf ten2vrf1 rd 172.31.254.70:2 evpn irb ve 8190 address-family ipv4 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ! address-family ipv6 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ! !  |
