You can administratively manage the state
		of an SLX device using the EFA command line.
		You can change a state to up or down,
			delete a state from the history, and view the state history and the current state. For
			details about the command and its parameters, see the
    Extreme Fabric Automation Command Reference,
     2.5.0
				To change a device to the up
					state, run the following command.
					$ efa inventory admin-state up --ip <device IP>
AdminStateUp [success]
Admin State Up execution UUID: 8d9fa0cf-dc76-42cc-ac7a-57902a47c1b2
				This example changes the state for the specified IP address and generates a
					UUID, which you can use in the efa inventory admin-state
						detail version of the command.
				To change a device to the down
					$ efa inventory admin-state down --ip <device IP>
AdminStateDown [success]
Admin State Down execution UUID: 28eb0845-7a7a-4851-b453-b3020c6900f2
				To review the details of a state
					change, run the following command.
					$ efa inventory admin-state detail --uuid 28eb0845-7a7a-4851-b453-b3020c6900f2
				To view the history of the admin
					changes for a specified device, run the following command.
					# efa inventory admin-state history --ip <device IP>
				To display the admin state and the health check state of a device, run the
					following command.
					$ efa inventory admin-state show --ip <device IP>
				To delete the instance of the admin state change for a device, run the
					following command.
					$ efa inventory admin-state delete --key <device IP or UUID>
