Part number XN-ACPWR-1100W-FB provides 1100 W AC power with front-to-back airflow and is compatible with all 5720 Series switches.
The 1100 W AC power supply has a (C16) power inlet that requires a (C15) power cord.
AC power input cords are not provided with AC power supplies. You can order an appropriate cord from Extreme Networks or from your local supplier. The power cord must meet the requirements listed in Power Cord Requirements for AC-Powered Switches and AC Power Supplies.The 1100 W AC power supply has the status LEDs listed in the following table:
IN_OK (Green) | OUT_OK (Green or Red) | Description |
Off | Off | No AC input power connection or low AC voltage. |
On | Off | AC input good, 54V output disabled. |
On | (Red) On | AC input good, output (54V) fault. |
On | (Green) On | AC input good. |
For information on installing or replacing a power supply, see Replace Power Supplies.
