Power Specifications
Power Supply Specifications
715W AC PSU1100W AC PSU2000W AC PSU1
Voltage Input Range (Nominal)100-127/200-240 VAC100-127/200-240 VAC100-127/200-240 VAC
Line Frequency Range50Hz to 60Hz50Hz to 60Hz50Hz to 60Hz
Power Supply Input SocketIEC/EN60320 C16IEC/EN60320 C16IEC/EN60320 C16
Power Cord Input PlugIEC/EN60320 C15IEC/EN60320 C15IEC/EN60320 C15
Operating Temperature
0°C to 55°C (32°F to 131°F)
Normal Operation
0°C to 50°C (32°F to 122°F)
Normal Operation
1 200-240 VAC is required to achieve full 2000W output. If run at 100-120VAC, output is limited to 1100W.
  • The ambient temperature of the operating environment must not exceed 45°C at sea level when using the 1100W or 2000W power supplies.
  • The ambient temperature of the operating environment must not exceed 40°C at 1,500 meters.
  • The ambient temperature of the operating environment must not exceed 35°C at 3,000 meters.
  • The ambient temperature of the operating environment can be in the range of 0°C to 50°C at sea level to 3,000 meters when using 5720 models with the 715W power supply.
Minimum/Maximum Power Consumption and Heat Dissipation
Switch ModelMinimum Power Consumption (W)Minimum Heat Dissipation (BTU/hr)Maximum Power Consumption (W)1Maximum Heat Dissipation (BTU/hr)2
5720-24MW862932549389
5720-24MXW1053592576416
5720-48MW1033544078543
5720-48MXW1053594096561
1 Includes maximum PoE load (W) through the switch
2 Does not include PoE load heat dissipated through external electronic load
PoE Power Budget
Switch Model1 x 715W2 x 715W1 x 1100W2 x 1100W1 x 2000W @
110-132V AC
2 x 2000W @
110-132V AC
1 x 2000W @
220-264V AC
2 x 2000W @
220-264V AC
5720-24MW450W1093W835W1825W835W1825W1735W2160W
5720-24MXW450W1093W835W1825W835W1825W1735W2160W
5720-48MW450W1093W835W1825W835W1825W1735W3535W
5720-48MXW450W1093W835W1825W835W1825W1735W3535W
It is recommended that primary and secondary power supply units (PSUs) be of the same type to support optimal PoE operation.
