The 5720-VIM-6YE versatile interface module provides six 10/25GbE SFP28, MACsec capable ports. The six ports are divided into two groups which must be configured at the same speed. Ports 1, 2, and 3 are the first group and must be configured together at the same speed, such as 10 GbE. Ports 4, 5, and 6 are the second and must be configured together at the same speed, such as 25 GbE. Or Group 1 can be configured at 25 GbE and Group 2 can be configured at 10 GbE. See 5720-VIM-6YE Versatile Interface Module for reference.
For information about the supported optical modules, refer to the most recent version of the Extreme Optics website.
Switch Engine | Fabric Engine (all models) | |
24MW and 24MXW models | 27, 28, 29, 30, 31, 32 | VIM slot number=2 Interface names=2/1-2/6 |
48MW and 48MXW models | 51, 52, 53, 54, 55, 56 |
An LRM/MACsec adapter can be used with the 5720-VIM-6YE versatile interface module, but is only used for its LRM capability. MACsec is supported natively on the ports the LRM/MACsec adapter is connected to on the versatile interface module. The following table details the maximum number of LRM/MACsec adapters you can use. The maximum number varies according to:
Switch Model | Mode: LRM only | Mode: LRM and MACsec | ||
Two ports no aux. power | Two ports 0.5A aux. power | Two ports aux. power1 | One port one bypass aux. power1 | |
5720-VIM-6YE | 2 | 3 | N/A | N/A |
1With 1W optics modules (SR, LR, LRM, 10 km bidirectional, AOC, DAC, and most 1 Gb optics), use 0.5A auxiliary power sources.
