2000 W AC Power Supply
Part number XN-ACPWR-2000W-FB provides 2000 W AC power with front-to-back airflow and is compatible with all 5720 Series switches.
In order to obtain 2000W output from this power supply, the PSU must be connected to a 200-240VAC source.
The 2000 W AC power supply has a (C16) power inlet that requires a (C15) power cord.
AC power input cords are not provided with AC power supplies. You can order an appropriate cord from Extreme Networks or from your local supplier. The power cord must meet the requirements listed in Power Cord Requirements for AC-Powered Switches and AC Power Supplies.
The 2000W power supply unit with System Number 801098 has multiple hardware revisions that are indicated by the final two characters. Revisions 801098-00-AA and 801098-00-AB are not compatible with the 5720 Series. Those revisions are only compatible with the 5520 Series and VSP 4900 Series. To use the 2000W power supply with the 5720 Series, the revision must be 801098-AC or later.
The 2000 W AC power supply has the status LEDs listed in the following table:
Table 1. 2000 W AC Power Supply LED Status Indications
IN_OK (Green)OUT_OK (Green or Red)Description
OffOffNo AC input power connection or low AC voltage.
OnOffAC input good, 54V output disabled.
On(Red) OnAC input good, output (54V) fault.
On(Green) OnAC input good.
For information on installing or replacing a power supply, see Replace Power Supplies.
