On some Extreme Networks switch models, you can configure QSFP28 ports either as single ports or as multiple, partitioned ports in Switch Engine, or channelized ports in Fabric Engine. In a partitioned or channelized port, with appropriate cabling, the original physical port can accommodate multiple data lanes at lower bandwidths. Ports are not partitioned by default.
The following options are available:
Device | Port Bandwidth | Port Partitions/Channels |
5720 (all models) QSFP28 (U1 and U2 ports) | 100 Gb | One U1 or U2 port with one of the following:
5720-VIM-6YE SFP28 | 25 Gb | The 5720-VIM-6YE has two speed groups, each with three ports that can be partitioned with the following:
5720-VIM-2CE QSFP28 | 100 Gb | The 5720-VIM-2CE has two ports, each of which can be partitioned with the following:
For information about configuring partitioned ports, see the Switch Engine Command References for your version of the Switch Engine operating system, or the Fabric Engine Command References for your version of the Fabric Engine operating system.
