LRM/MACsec Adapter Technical Specifications
The LRM/MACsec Adapter (part no. 10965) can be attached to switch ports that are not LRM or MACsec capable, using a cable that is specifically designed for this purpose.
Table 1. LRM/MACsec Adapter Packaged Dimensions
Height3.00 cm (1.18 in)
Width7.60 cm (2.99 in)
Length12.35 cm (4.86 in)
Weight300 g (0.66 lb)
LRM/MACsec Adapter Environmental Data and Standards
Table 2. Environmental Data
Operating temperature
0°C to 40°C (32°F to 104°F) when used with the following optics modules:
  • Tunable DWDM SFP+ (part no. 10325)
  • ER SFP+ (part no. 10309)
  • ZR SFP+ (part no. 10310)
  • Bidirectional 120 km SFP (part nos. MGBIC-BX120-U and MGBIC-BX120-D)
0°C to 45°C (32°F to 113°F) when used with all other supported optics modules
Storage and transportation temperature
-40°C to 70°C (-40°F to 158°F)
Humidity
10% to 95% relative humidity, non-condensing
Altitude
0 to 3,000 meters (9,850 feet)
Table 3. Safety Standards
North American Safety of ITE
UL 62368-1:2014, Listed Device (US)
UL 60950-1 2nd Ed., A2:2014, Listed Device (US)
CAN/CSA 22.2 #62368-1-14:2014 Canada)
European Safety of ITE
EN 62368-1:2014
EN 60950-1:2006+A11+A1+A12+A2
IEC 62368-1:2014
IEC 60950-1:2005 2nd+A1:2009+A2:2013
2014/35/EU Low Voltage Directive
Five-Slot Bracket
Table 4. Five-Slot Bracket for LRM/MACsec Adapter: Specifications
Part no.10966
Height4.32 cm (1.70 in)
Width48.26 cm (19.00 in)
Length5.00 cm (1.97 in)
Weight487 g (1.07 lb)
