System status LEDs are located on the panel front of the switch. The following table describes the colors and the states for the LEDs.
LED | Color/State | Port State |
SYStem status LED Note: The system status LED is solid green to indicate normal operation when the switch is running Fabric Engine.
(Legacy MGMT function) | Slow blinking green | POST Passed, normal operation, blinks on standalone switch, stack primary, and backup nodes in a stack; off for standby nodes in a stack |
Blinking green | POST in progress | |
Blinking amber | POST failed or overheat | |
PSU status LEDs (P1/P2) | Solid green | Power On |
Off | Power off and no power attached | |
Blinking amber | Power supply failures | |
Fan status LEDS (F1/F2/F3/F4) | Solid green | Normal operation |
Blinking amber | Fan failure | |
Bluetooth Status LED (BT) | Blinking green | Bluetooth pairing in progress |
Solid green | Bluetooth connected | |
Locator LED (LOC) | Blinking blue | Locator function |
Port LEDs can display in three different modes: SYS (the default mode), SPD (speed) and STK (stacking). The Mode button cycles through the three display modes. In the default SYS mode, SPD and STK are off. The port LEDs enter SPD display mode, indicated by the SPD LED, after pressing the Mode button one time. SPD mode helps to determine the operational speed of a port. The port LEDs enter the STK display mode, indicated by the STK LED, after pressing the Mode button a second time. STK mode is used to indicate slot presence and slot number through the first eight port LEDs. SPD and STK display modes expire after 30 seconds, and the display mode reverts back to the default SYS mode. A long press of the Mode button when in any mode other than STK mode initiates Bluetooth pairing. 5720 Series Mode and System Status LEDs shows the two alternate mode LEDs: SPD and STK.
The Mode button also supports the instant stacking feature. To instantly stack switches, first ensure that the SPD/STK LED is on STK by pressing the Mode button until the LED is green. Press and hold the Mode button for at least five seconds, then release the Mode button after five seconds. The front panel port LEDs on the primary node flash in an alternating pattern followed by a delayed reboot of all of the switches. The LEDs flash for approximately 15 seconds prior to the reboot. After the reboot completes, the switches are stacked.
Front-panel PoE ports use Amber to indicate PoE states.In the default SYS mode, SPD and STK are OFF. Port status displays behavior for link, traffic, and PoE as described in the following table:
Solid green | Link is OK; port is not PoE powered |
Solid amber | Link is OK; port is PoE powered; no traffic |
Blinking green | Link is OK and transmitting packets; port is not PoE powered |
Blinking amber | Link is OK and transmitting packets; port is PoE powered |
Slow blinking amber | No link, or disabled port; port is PoE powered |
Alternating amber and green | Port has a power fault |
Off | Port is not PoE powered, has no link, or is disabled |
RJ45 and SFP ports have a single LED per port. QSFP ports have four LEDs because QSFP ports can be divided into four different channels, each of which can indicate link and activity independent of the other channels. When a QSFP port is divided, each LED indicates the rate of an individual channel. When a QSFP port is used as single port, all of the channel LEDs indicate the rate of the single port. Color and blink pattern indicate speeds, as referenced by the following table:
Color/State | Speed |
Fast blinking green | 100Mbps |
Solid green | 1Gbps |
Slow blinking amber | 2.5Gbps |
Fast blinking amber | 5Gbps |
Slow blinking green | 10Gbps |
Fast blinking green | 25Gbps |
Fast blinking green | 40Gbps |
Fast blinking green | 50Gbps |
Fast blinking green | 100Gbps |
STK mode indicates slot presence and slot number through the first eight port LEDs, as referenced by the following table.
Port 1-8 Color/State | Speed |
Solid green | Slot corresponding to the port number of the LED is present |
Blinking green | Slot number corresponding to the port number of the blinking LED |
The management port uses two LEDs to indicate port activity and link status, as referenced by the following table
LED | State | Description |
Link/Speed | Off | Operating at 10Mbps |
Solid amber | Operating at 100Mbps | |
Solid green | Operating at 1Gbps | |
Act | Off | No link |
Solid green | Link is OK; no traffic | |
Blinking green | Link is OK and transmitting packets |
[enable | disable] led locator.
