Switch Model | Interfaces |
5720-24MW |
5720-48MW |
5720-24MXW |
5720-48MXW |
5720-VIM-6YE |
5720-VIM-2CE |
Part Number | Weight | Physical Dimensions |
5720-24MW | 8.05 kg (17.75 lb.) |
Height: 43.2 mm (1.7 in.) Width: 444.5 mm (17.5 in.) Depth: 525.8 mm (20.7 in.) |
5720-48MW | 8.55 kg (18.85 lb.) | |
5720-24MXW | 8.05 kg (17.75 lb.) | |
5720-48MXW | 8.55 kg (18.85 lb.) | |
5720-VIM-6YE | 0.24 kg (0.53 lb.) |
Height: 40.6 mm (1.6 in.) Width: 50.8 mm (2.0 in.) Depth: 175.3 mm (6.9 in.) |
5720-VIM-2CE | 0.22 kg (0.49 lb.) |
XN-ACPWR-715W-FB (715 W AC Power Supply) | 2.55 lb (1.12 kg) | Height: 1.57 inches (4.0 cm) Width: 3.25 inches (8.3 cm) Length: 10.22 inches (26.0 cm |
XN-ACPWR-1100W-FB (1100 W AC Power Supply) | ||
XN-ACPWR-2000W-FB (2000 W AC Power Supply) | 2.95 lb (1.34 kg) | With handle: Height: 1.57 inches (4 cm) Width: 3.25 inches (8.25 cm) Length: 11.51 inches (29.25 cm) Without handle: Height: 1.57 inches (4 cm) Width: 3.25 inches (8.25 cm) Length: 10.25 inches (26.05 cm) |
