Add a Building
Your network hierarchy must contain at least one site with the country code defined, before you can add buildings and floors.
Use this task to add a new building to your network plan.
  1. Go to Manage > Planning.
  2. Locate the site to which you want to add the building, and select Add icon.
  3. In the Add Building dialog, type a Name for the new building.
  4. Type the building Address and City, and then select the State.
    Alternately, use Google Maps search to automatically populate the address. If you manually adjust the marker on the map, the address updates automatically.
    While sites do not require addresses, it is expected that buildings have addresses.
    While State is a required field for the US address format, the Province/State/Region field is optional for the international address format.
  5. Select SAVE.
