Create or modify a switch template.
You can group individual ports into aggregate ports on 24- and 48-port switches by selecting two or more ports of the same type on the switch template.
You can change the LAG port type after a port has been assigned to a LAG, without having to delete and recreate the LAG.Continue configuring the switch template.
