A VLAN defined within Instant Port Profiles as Non-Forwarding cannot be used to create a routing interface.To configure routing:
| Field | Description |
| Device (Mandatory) | Select a Device from the drop-down menu. Only standalone or stack EXOS/Switch Engine switches with this policy assigned can be selected. |
| Network Allocation (Mandatory) | Select a Network Allocation from the drop-down menu. Note: You cannnot assign a device to the same subnetwork twice or multiple subnetworks referencing the same VLAN ID or subnetworks with overlapping subnet space.
| VLAN Attribute (Read-only) | Select a VLAN Attribute from the drop-down menu. Note: This field displays <VLAN ID> / <VLAN name> / <VLAN attribute created from>. For IPv4 interfaces created from a network policy, it will display the VLAN ID and VLAN name from the selected subnetwork and "POLICY" as the source for the VLAN attribute.
| IPv4 Address / Subnet Mask (Mandatory) | Shows the assigned IP Address, such as 10.1.0.0/16. Note: IPv4 address must be a host address within the same subnet space as the selected subnetwork.
| Routing Instance (Read-only) | Shows the Routing Instance. Note: IPv4 interfaces can only be created within VR-Default.
| IPv4 Forwarding | Enables/disables IPv4 forwarding. |
| VLAN Loopback | Enable or Disable VLAN Loopback. |
| DHCP Relay (Read-only) | DHCP Relay configured within the selected subnetwork or allows overriding DHCP Relay from subnetwork with a custom configuration. |
