Configure an Extreme Networks device as a RADIUS proxy server and
create a realm.
This task is part of the network policy configuration workflow. Use this task to optimize the realm settings for a RADIUS proxy.
On the Configure
RADIUS Servers page, select REALM
SETTINGS.
Select a User and Realm Name format:
- NAI (Network Access
Identifier)—The standard syntax is
user@realm.
- Windows NT Domain—The
standard syntax is
user1@example.com.
- SPN (service principal
name)—The standard syntax is
serviceclass/host.
- AUTO—Extreme
automatically applies a format.
Type the Retry
Delay—The time interval between retries.
Type the Retry
Count—The number of retries before declaring failure.
Type the Dead
Time—The time elapse (in seconds) before declaring
failure.
Select Inject
Operator-Name Attribute.
If you do not want to inject an operator-named attribute, clear the check
box.
Select SAVE RADIUS PROXY.
Finish configuring the RADIUS proxy.
