The IoT Profiles list displays the following information:
| Column Heading | Description |
| Name | Displays the name assigned to the profile. |
| IoT Application | Indicates the type of IoT application for which the profile is used. |
| Used By | Indicates at which device configuration level the profile is assigned: Device Template or Device Configuration. |
Use this task to add a new IoT profile to the list, or to edit, clone, or delete existing IoT profiles.
See Configure IoT Profile Settings.
