LLDP is on by default in ExtremeCloud IQ. In IQ Engine, LLDP was previously off by default. With IQ Engine Release 10.7.5 and later, LLDP is on by default. This is the new default behavior for all new devices running 10.7.5 and later.
If LLDP is disabled in the network policy, upgrading to 10.7.5 enables LLDP until after you perform a configuration update.
The Search field helps you find a specific location in a large network. Enter the first few characters to see a list of locations. The more characters you enter, the more precise the search results will be.| Field | Description | |
| Update Network Policy and Configuration: | ||
| Delta Configuration Update | To update only the configuration changes for the selected device, select Delta Configuration Update. ExtremeCloud IQ only updates the device deltas. This action will avoid a device reboot. | |
| Complete Configuration Update | If a full update is required, select Complete Configuration Update. Used to reset the selected AP to ExtremeCloud IQ configuration settings. Note: Only supported on devices running HOS or IQE Firmware.
| Upgrade IQ Engine and Extreme Network Switch Images: | ||
| Upgrade to the latest version |
Upgrade to the latest firmware version. | |
| Upgrade to the specific version |
Select a Model to upgrade, and then select the Version to upgrade to from the drop-down list. To add a new version (local image), select Add/Remove:
Select View Release Notes to access the Online Help system and see the latest release notes. | |
| (Optional) Upgrade even if the versions are the same | Enforce an upgrade to the same version as the current version. | |
| Activation Time for Extreme Networks Devices Running Images: | ||
| Activate at next reboot (requires rebooting manually) | Activation takes affect the next time the AP is rebooted. | |
| Activate after xx seconds | The delay before activation, in seconds. | |
| Activate/reboot on this schedule based on your local system time | Schedule a Date and Time to activate. | |
| Field | ||
| Reboot and revert Extreme Networks switch configuration if IQAgent is unresponsive after configuration update. |
Note: Not supported on Dell/SR.
| Perform delta configuration update and resolve local device configuration which is out of sync with ExtremeCloud IQ. | ||
| Upgrade IQ Engine and Extreme Network Switch Images | ||
