Go to any of the following user interfaces:
Manage > Devices <select an IQ Engine AP > Utilities > Tools > Packet Capture
ML Insights > Client 360 <optionally, select an active client > Utility > Packet Capture
If a packet capture is initiated through Client 360 and an active client is selected, when the New Packet Capture window opens, the client's MAC address is prefilled in the Clients field, and the client's associated AP is preselected. Add other APs to the packet capture, as required.Use this procedure to configure Packet Capture parameters and start a Packet Capture session.
After a session starts, package capture parameters cannot be modified.
If the target APs selected in step 2 include model types that support Enhanced Packet Capture and other model types that support basic Packet Capture, only the basic Packet Capture parameters are available for configuration.| Parameter | Description |
| Filter Settings | |
| Direction | Filters packet capture on the basis of the direction of
packet flow. Options are:
| Clients | Filters packet capture on the basis of packets received
from and transmitted to clients associated with the selected
AP. Options are:
| Where has the client recently roamed? | Provides the option to add to the Packet Capture session
any APs involved in client roaming over the previous seven
days. Select Update Selected APs. In the Select APs from Client Trail pop-up window, select one or more APs, then select OK. |
| VLANs | Filters packet capture on the basis of packet
transmission over specific VLANs. Enter an individual VLAN ID or a range of VLAN IDs. Indicate a range with a hyphen. Separate VLAN entries with commas. Example: 2,4,5-10. |
| Protocol | Filters packet capture on the basis of protocol. Choose
from the following options:
| Wireless | |
| Band | Filters packet capture on the basis of radio
band. Select Band, then use the drop-down list to choose from of the following options:
Note: ExtremeCloud IQ automatically discovers the
radio interface(s) on the target AP that support the
selected radio band(s). If there is no radio on the AP
to support the configured band, the packet capture
session fails.
| Interface | Filters packet capture on the basis of radio
interface. Select Interface, then use the drop-down list to choose from of the following options:
| WLANs | Filters packet capture on the basis of the traffic over
WLAN(s). Use the drop-down list to choose from of the following options:
| Filters | Filters packet capture on the basis of network traffic
functions. Select one or more of the following options:
| Wired | |
| Interface | Filters packet capture on the basis of Ethernet port.
Use the drop-down list to choose either:
Note: If
a target AP has a disabled Ethernet port that is
specified here, the packet capture for the interface
fails.
| Filters | Filters packet capture on the basis of protocol. Select one or more of the following options:
| Capture Settings | |
| Duration | Indicates the period of time after Start
Capture is selected during which packets are
captured. This option is enabled by default. Options are:
| Upload to CloudShark | Indicates whether tar files containing
PCAP files from packet capture operations on individual interfaces
are uploaded to CloudShark. This option is enabled by
default. Note: Uploading files to CloudShark requires an existing
account.
| CloudShark API Token | Specifies the API access token. Enter a value consisting of 32 hex characters (0-9, a-f). |
| Wireless | |
of radio interface.
account.
