When defining Credential Distribution groups, the required details for Admin Account depend on the specific type of administrative account.In most cases, you enter the email address associated with the Guest Management account in Account Management Settings. However, if the Guest Management account was created automatically by Self-Service SSO (and has a blue SSO badge), you must use the automatically generated saml.login user ID (such as, abcdefg12345@saml.login). This value must be obtained by the GET /users XAPI call. For more information, see the ExtremeCloud IQ XAPI Swagger or ExtremeCloud IQ API Reference.
| Setting | Description |
| Group Name | (Required) Type a name for the group. |
| Admin Account | (Required) From the menu, choose Active Directory User or Guest Management Role User. |
| Member Of | Active Directory User only Enter the Active Directory user group for the account. If the account is a member of multiple groups, type the name of the first group, press Enter, and then enter the next group name. |
| Guest Management User | (Required) Guest Management Role
User only Enter the access control role to assign to a group member. |
| Credential Restriction | Select Restrict the number of credentials per employee to, and then select the number of credentials that group members can distribute. |
| Registration Operation | Select Email Approval. |
| Enable User Groups | Add existing user groups to add to this credential distribution group either by selecting Select All, or by selecting the check boxes for individual user groups. |
