Extreme Networks and Dell EMC recommend that you enable STP for Dell EMC switches.
Extreme Networks switches can use Spanning Tree Protocol (STP) to activate links with the lowest cost (highest bandwidth), establish backup links where possible, and prevent Layer 2 network loops, which can result in duplicate unicast frames and broadcast storms. Bridge Protocol Data Unit (BPDU) protection is a security feature designed to protect the active STP topology by preventing spoofed BPDU packets from entering the STP domain. BPDU protection is applied to edge ports connected to end-user devices that do not run STP. If an STP BPDU protected port receives packets, this feature disables that port and alerts the network admin.
The BPDU Restrict feature disables the port as soon as a BPDU is received on the BPDU restrict port, blocking the loop. Specify a BPDU recovery timeout, enabling the port after the configured amount of time.
You can enable BPDU Restrict only when Edge port is also enabled.By default, STP is disabled. Use this task to enable STP and configure the settings for an individual port, on the STP tab.
A port configured as an edge port will not cause a loop upon network topology changes.
You can manually designate a port to act as a root bridge by assigning port priorities.
After the time expiresExtremeCloud IQ re-enables the port automatically.
