| Setting | Description |
| Name | Type a Name for the group. |
| Description | (Optional) Type a Description for the group. Although optional, entering a description is helpful for troubleshooting and for identifying the group. |
| Connectivity | Select either Backhaul Connectivity Tracking for APs or WAN Interface Connectivity Tracking for APs. |
| Enable IP Tracking | To activate this IP tracking group, select the check box. Clear the check box to exclude the group from Available IP Tracking Groups. |
| Track the Following Targets | |
| IP Addresses | Enter up to four IP addresses, separated by commas. If you are also tracking the default gateway, enter up to three IP addresses. |
| Default Gateway | If the IP addresses use the default gateway, select Default Gateway. Otherwise, clear the check box. |
| Take action when | From the menu, select a condition for which to take action. Choose between All targets become unresponsive and A single target becomes unresponsive. |
| Tracking Interval | (Required) Type the tracking interval for this group. Default: 6 |
| Tracking Retries | (Required) Type the number of retries before taking action for an IP address failure. Default: 3 |
| Actions to take when target becomes unresponsive | |
| Enable the virtual access console | Select the check box to take this action when the target is unresponsive. |
| Disable all active SSIDs | Select the check box to take this action when the target is unresponsive. |
| Start the backhaul (mesh) failover procedure | Select the check box to take this action when the target is unresponsive. |
