The settings depend on the rule Type that you select. Choose from the following types:
| Setting | Description |
| Type | Select the type of rule: Host Name, Server IP Address, or Port Number from the menu. |
| Protocol | Select the protocol: HTTP or HTTPS from the menu. |
| Host Name | (Required) Type the host name. |
| Type | Select the type of rule: Host Name, Server IP Address, or Port Number. |
| Protocol | Select the protocol: TCP or UDP from the menu. |
| Server IP Address | (Required) Type the IP address for the server. |
| Port Number | Type the port number. Range: 1-65535 |
| Port | (Required) Type the port number. Range: 1-65535 |
