Complete the Add a Network Policy task.
This task is part of a series for configuring the Optional Settings for a standard wireless network. Use this task to customize the Other Options.
This method provides very little protection against anything but the most casual intrusion efforts.If the civic address, latitude, longitude, or altitude of the AP is configured, the AP advertises this information in the beacon.
Enabling FTM (Fine Timing Measurement) 11mc causes a radio reset.If you select Broadcast SSID Using > 6 GHz radio, ExtremeCloud IQ enables this feature by default. If you turn off 6 GHz radio, ExtremeCloud IQ disables this feature.
Finish configuring the network policy.
