Go to .
The Alerts dashboard includes:
Alerts are supported for devices that are connected directly to ExtremeCloud IQ cloud management only. Devices that appear in ExtremeCloud IQ but are managed by ExtremeCloud IQ Controller, the ExtremeWireless WiNG implementation, or ExtremeCloud IQ Site Engine will not generate alerts.
The ExtremeCloud IQ Pilot banner displays a Notifications iconSelect Alert Policy to modify the Global Policy or to create or modify a Site Policy.
Select View Legacy Alarms to view legacy alarms.
By default, the Alerts dashboard displays information about alerts raised at all sites for the last 24 hours. You can filter the Alert Details list using either one or a combination of the following methods:
After you set filters, if you exit the Alerts dashboard, the filters do not persist. You cannot save filter settings.The Alert Details pane lists alerts and related details in tabular form. Alert Details List Column Headings describes the type of information displayed in each column and the tools users can employ.
| Column Heading | Description |
| Severity | Displays alert severity levels, as follows:
| Summary | Provides an interactive description of the alert. Select the
description to open the Alert
Detail pop-up window, which displays variations of
the following information, depending on the source of the alert:
In the Alert
Detail window, choose from the following
actions:
Note: Alerts can apply to specific device models based on the feature
support. For example, the alert: Switch SSH
Login Failed applies to switches running EXOS (Switch
Engine) and VOSS (Fabric Engine) only.
| Category | Identifies the category of the alert. Possibilities are:
| Source | Displays an interactive device host name. Select the host name to open the window to investigate the related alert issue. |
| Detected | Indicates when the event was detected or the performance metric criteria was met. |
| Acknowledge | Identifies the acknowledgment status of the alerts, as
follows:
Choose from the following actions:
Alert widgets provide a graphical summary of alerts and include color-coded refinements based on severity, category, and most prolific types of alerts. Widgets are interactive, allowing users to filter the alerts in the Alert Details list based on the refinements.
This widget displays the total number of Alerts Raised for the specified time range, with the colored bands of the arch and color-matched beads below it representing refinements on the basis of Severity, as follows:
Select a colored band in the graphic, or a bead, to filter the Alert Details list on the basis of Severity.
This widget displays the total number of Alerts Raised in all categories for the specified time range. Colored bands of the graphic and color-matched beads below it represent refinements based on Alert Category, as follows:
Select a colored band in the graphic or a bead to filter the Alert Details list on the basis of Alert Category.
This widget displays the five most prolific alert types raised for the specified time range. Select a colored band in the graphic to filter the Alert Details list on the basis of Alert Type.
