At this level, you are making changes to the selected switch only. These changes always override the network policy configurations. To revert to the settings in the network policy, from the Device List, select the switch host name, and use the Actions button.A root admin has complete privileges, which include the ability to add, modify, and delete other administrators, and to reset the configuration. A read-only admin can view settings but cannot add, modify, or delete them. You can require that an admin be prompted for a password before accessing high-level privileged CLI commands. To configure a root admin with full capability, follow these steps:
