After you create a meter, you can configure the meter using the command for the platform you are using. To configure a QoS meter on all platforms, use the following command:
configure meter metername {committed-rate cir [Gbps | Mbps | Kbps | Pps]} {max-burst-size burst-size [Kb | Mb | packets]} {out-actions [{disable-port} {drop | set-drop-precedence {dscp [none | dscp-value]} {dot1p [ none | dot1p-value ]}} {log} {trap}]} {ports [port_group | port_list]}
The disable-port, log, and trap options are only allowed for per-port meters (i.e. ingmeter0, ingmeter1,...).
