The following tables, groups, and variables are supported in this MIB.
| Table/Group | Supported Variables | Comments |
| extremeAutoProvisionConfig | Enables or disables the Auto Provision feature on the switch. |
The following traps can be generated.
| Trap | Notification Objects | Comments |
| extremeAutoProvisionStatus | This trap reports the auto provision result (success/failed). It contains the attributes it received from the DHCP server. | |
| extremeAutoProvisionResult | Result of the Auto provision. | |
| extremAutoProvisionIpAddress | The IP address received from the DHCP server for this interface. | |
| extremeAutoProvisionGateway | The gateway address received from the DHCP server for this interface. | |
| extremeAutoProvisionTFTPServer | The IP address of the TFTP server received from the DHCP server. | |
| extremeAutoProvisionConfigFileName | The configuration file name received from the DHCP server which the auto-provision enabled switch will download from the TFTP server and apply. It can use either the cfg or xsf extension. |
