When you configure a stack manually, each node in the stack must be assigned a unique slot number. You can assign the slot number only through configuration; the stack does not dynamically assign a slot number. The available slot numbers are 1 through 8. You can specify a slot number for each node manually, or you can have the system assign the slot numbers using a single command.
Slot numbers take effect only after a restart. If you change a slot number, the unit continues to operate with the slot number it was last restarted with.where mac_address is the node's MAC address.
A node that boots in standalone mode does not use a slot number.
