ExtremeXOS® v33.4.1 User Guide
Identity Management
> Enabling and Disabling SNMP Traps
Extreme Networks July 01, 2025
Abstract
Terminology
Related Publications
Getting Started
Product Overview
Software Required
Auto-provisioning Process
Cloning Switches
Using Clone.py
Cloning within a Stack
Logging in to the Switch
Using the CLI
Syntax Helper
CLI File Name Completion
Object Names
Reserved Keywords
Abbreviated Syntax
Command Shortcuts
Command Aliases
CLI History Lookup
Symbols
SummitStack Numerical Ranges
Line-Editing Keys
Common Commands
Using Safe Defaults Mode
Adjusting Bootup Time
Configuring Management Access
Account Access Levels
User Accounts
Administrator Accounts
Lawful Intercept Account
Configure Banners
Default Accounts
Creating Management Accounts
Failsafe Accounts
Managing Passwords
Timed Lockout
Displaying Passwords
Using DNS Cache Resolver
Using DNS Cache Analytics
Checking Basic Connectivity
Ping
Traceroute
Displaying Switch Information
Managing the Switch
Using the Console Interface
Authenticating Users
RADIUS Client
Management Accounts
Using Telnet
Starting the Telnet Client
About the Telnet Server
Using a BOOTP or DHCP Server
Viewing Telnet Information
Disabling and Enabling Telnet
Managing ACL Rules for Telnet
Sample ACL Policies
Using Secure Shell 2
Managing ACL Rules for SSH2
TFTP Block-size Configuration
Node Election
Determining the Primary Node
Relinquishing Primary Status
Bulk Checkpointing
Dynamic Checkpointing
Viewing Checkpoint Statistics
Viewing Node Status
Node Status Collected
Hitless Failover Caveats
Caveats for a SummitStack
Using Power Supplies
VR Configuration Support
Configuring Restrict Lists
Managing NTP Peer Support
Managing NTP Authentication
Showing NTP Information
NTP Configuration Example
SNMP Authentication Traps
Accessing Switch Agents
Supported MIBs
Configuring SNMPv2c Settings
Displaying SNMP Settings
Message Processing
SNMPv3 Security
USM Timeliness Mechanisms
Users, Groups, and Security
Managing Users
Configuring Password Rules
Managing Groups
Security Models and Levels
SNMPv3 Notification
Configuring Target Addresses
Managing Notification Tags
Configuring Notifications
Managing ACL Rules for SNMP
Configuring and Using SNTP
GMT Offsets
SNTP Example
Managing ACL Rules for HTTP
Copying Files on the Switch
Managing ExtremeXOS Processes
Stopping Processes
Starting Processes
Creating Processes
Configuring Stacked Switches
Introduction to Stacking
Building Basic Stacks
Slot Numbers in Stacks
SummitStack Topologies
Available Stacking Methods
SummitStack Terms
QoS in Stacking
QoS Profile Restrictions
QoS Scheduler Operation
Effects on 802.1p Examination
Stacking Link Overcommitment
Log Messages from Stack Nodes
Configuring a Stack
Manually Configuring a Stack
Configuring Slot Numbers
Verifying the Configuration
Managing an Operational Stack
Logging into a Stack
Managing Licenses on a Stack
Enabling a Switch License
Upgrading Stack Licenses
Performing a Rolling Upgrade
Reverting a Rolling Upgrade
Finishing a Rolling Upgrade
Upgrading the Bootrom
show vlan mgmt Command
show ipconfig mgmt Command
Configuring Master-Capability
Rebooting a Stack
Merging Two Stacks
Example: Merging Two Stacks
Removing a Node from a Stack
Dismantling a Stack
Troubleshooting a Stack
Daisy Chain
Broken Stack (Isolated Nodes)
Failed Stack
Failed Stack Node
License Mismatch
Stacking Link Failure
Understanding Stacking Traps
Configuring Ports on a Switch
Port Groups
Flow Control
IEEE 802.3x Flow Control
Fabric Port Configuration
Running Link Fault Signal
Turn off Autopolarity
Enabling IPFIX
Configuring Domain IDs
Configuring a Collector
Unconfiguring IPFIX
Displaying IPFIX Information
Default Switching Mode
DWDM Optics Support
Configuring DWDM
Displaying DWDM
Jumbo Frames
Guidelines for Jumbo Frames
Enabling Jumbo Frames
Path MTU Discovery
Load-Sharing Algorithms
Address-Based Load Sharing
Port-Based Load Sharing
LACP
LACP Fallback
Health Check Link Aggregation
Guidelines for Load Sharing
Load Sharing Guidelines
Configuring LACP
Load-Sharing Examples
LACP Example
Health Check LAG Example
MLAG Overview
ISC Blocking Filters
Linkup Isolation
Inter-Switch Communication
PIM MLAG Support
Traffic Flows
MLAG Peer Port Failure
FDB Checkpointing
Layer-2 IP Multicast
Configuring MLAGs
Displaying MLAG Information
Example of MLAG Configuration
MLAG-LACP
Mirroring
Guidelines for Mirroring
Configuring Mirroring
Remote Mirroring
Configuration Details
Configuring the Source Switch
Remote Mirroring Guidelines
Remote Mirroring with EAPS
Remote Mirroring With STP
Extreme Discovery Protocol
EXOS CDP Support
EXOS CDP Protocol Operations
Displaying Port Information
Port Isolation
Configuring Port Isolation
Node Alias Overview
Configuring Node Alias
ACLs
ACLs Overview
Two-Stage ACL
Feature Description
Two-Stage Policy Example
ACL Rule Syntax
Matching All Egress Packets
Types of Rule Entries
Match Conditions
Action Modifiers
Counting Packets and Bytes
Logging Packets
Metering Packets
Mirroring Packets
Redirecting Packets
ACL Rule Syntax Details
Fragmented Packet Handling
Wide Key ACLs
ACL Byte Counters
Dynamic ACLs
Creating the Dynamic ACL Rule
Configuring ACL Priority
Configuring User Zones
Network-Zone Support in ACLs
Creating a Network-Zone
Deleting a Network-Zone
Refreshing Network-Zones
show access-list network-zone
CVID ACL Match Criteria
CCOS ACL Match Criteria
ACL Evaluation Precedence
Precedence
Rule Evaluation
Precedence of Dynamic ACLs
Precedence with Egress ACLs
Redundant Rules
Applying ACL Policy Files
Example ACL Rule Entries
ACL Mechanisms
ACL Slices and Rules
Rule Evaluation and Actions
Slice and Rule Use by Feature
System Configuration Example
ACL Error Messages
Policy-Based Routing
Layer 3 Policy-Based Redirect
Layer 2 Policy-Based Redirect
LAG Port Selection
Multiple Next-hop Support
Packet Forward/Drop
ACL Troubleshooting
AVB
AVB Feature Pack License
Configuring and Managing AVB
MRP/MSRP/MVRP LAG Support
gPTP LAG Support
Displaying AVB Information
BGP Overview
BGP Four-Byte AS Numbers
BGP Attributes
BGP Community Attributes
Extended Community Attributes
Extended Community Processing
Syntax in Match block
Syntax in Set block
Extended Community Syntax
Multiprotocol BGP
Route Reflectors
Route Confederations
Inactive Route Advertisement
Using the Loopback Interface
Looped AS_Path Attribute
BGP Peer Groups
BGP Route Flap Dampening
Route Redistribution
BGP ECMP
BGP Mulitipath-Relax
BGP Static Network
Graceful BGP Restart
Cease Subcodes
Administrative Shutdown
Peer De-configured
Other Configuration Change
Fast External Fallover
Capability Negotiation
IPv4 Capability Negotiation
IPv6 Capability Negotiation
Route Refresh
Configure the BGP Router ID
Configure the AS Number
Configure the BGP MED
Configure BGP ECMP
Configure BGP Multipath-Relax
Configuring BGP Neighbors
Configuring Route Acceptance
Configuring Route Origination
Configure a Route Map Filter
Configuring BGP Peer Groups
Configure Route Aggregation
Configure Route Reflectors
Managing BGP
Refresh BGP Routes
Configure BFD for BGP
Reapply a Policy
Clear BGP Neighbor Counters
Displaying BGP Information
Display BGP Route Information
Display BGP Memory Usage
BGP IPv6 Example
Switch4 Configuration
Step 1
Step 2
Step 3
Output
Router A Configuration
Router B Configuration
BGP Auto-peering
Auto-peering Introduction
External Router Support
EVPN and VRF Support
Asymmetric Routing
Supported Platforms
Configuring BGP Auto-peering
BGP Auto-peering Examples
CLEAR-Flow
CLEAR-Flow Overview
Configuring CLEAR-Flow
CLEAR-Flow Rule Match Type
Count Expression
Delta Expression
Ratio Expression
Delta-Ratio Expression
Rule-True-Count Expression
CLEAR-Flow Rule Actions
Permit/Deny
QoS Profile
Mirror
SNMP Trap
syslog
CLI
Keyword Substitution
CLEAR-Flow Rule Examples
Count Expression Example
Delta Expression Example
Ratio Expression Example
Data Center Solutions
Data Center Overview
Custom Application Support
Priority-based Flow Control
VM Port Configuration
VM Authentication Process
File Synchronization
Managing the DCBX Feature
Enabling DCBX on Switch Ports
DCBX Configuration Example
XNV and MLAG
XNV Dynamic VLAN
Creating the MANIFEST File
Creating a VMMAP File
Creating VPP Files
Creating Policy Files
Example XNV Configuration
MAC and IP Addresses
General VLAN Configuration
VMWare Server Setup
Repository Server Setup
Example ACL Rules
EAPS
EAPS Protocol Overview
EAPS Benefits
EAPS Single Ring Topology
EAPS Multiple Ring Topology
fast convergence
EAPS Licensing
Configuring EAPS
Adding the EAPS Control VLAN
Adding Protected VLANs
Configuring the Ring Ports
Clearing the EAPS Counters
Displaying EAPS Information
Migrating from STP to EAPS
CFM Support in EAPS
Binding to a MEP Group
Displaying EAPS Output Change
Platforms Supported
ERPS
ERPS Overview
Supported ERPS Features
G.8032 Version 2
CFM Link Monitoring
Force Switch
Clear Command
Manual Switch
R-APS Control MAC
Timers
Interoperability with EAPS
Sample Configuration
Configuring ERPS
ERPS Version 1 Commands
ERPS Version 2 Commands
Debugging ERPS
ERPS Feature Limitations
ESRP
ESRP Overview
ESRP Master Election
Master Switch Behavior
Pre-Master Switch Behavior
Slave Switch Behavior
Neutral Switch Behavior
Electing the Master Switch
ESRP Failover Time
ESRP Election Algorithms
ESRP Domains
ESRP Groups
ESRP Extended Mode Features
Linking ESRP Switches
ESRP-Aware Switches
Configuring ESRP
Guidelines
ESRP Configuration Overview
ESRP and IP Multinetting
ESRP and STP
ESRP and VRRP
ESRP Groups and Host Attach
Port Configurations and ESRP
Using ELRP with ESRP
Configuring ELRP
Configuring Master Polling
Configuring Ports
Displaying ELRP Information
Advanced ESRP Features
ESRP Tracking
ESRP Environment Tracking
ESRP VLAN Tracking
ESRP Ping Tracking
ESRP Tracking Example
ESRP Port Restart
ESRP Host Attach
Selective Forwarding
Display ESRP Information
ESRP Configuration Examples
EVPN Overview
EVPN Supported Platforms
EVPN Limitations
EVPN Supported Route Types
Configuring EVPN Overview
Recommended Configuration
Configuring EVPN
EVPN Commands
Displaying EVPN Information
EVPN Configuration Examples
Extended Edge Switching
Important Terminology
Chassis Analogy
Edge Control Protocol
Redundant Controlling Bridges
Extended Edge Switching Rings
Forming a Ring
Link Failure Handling
Cross-Connect MLAGs
One-Arm MLAGs
Supported Platforms
ZTPStack Behavior
Software Upgrade
Rebooting VPEX
Manual Configuration Example
Fabric Attach Overview
Fabric Attach Operation Modes
Fabric Attach Proxy Mode
Fabric Attach Server Mode
Fabric Attach Client Mode
LLDP
RADIUS/Policy/NetLogin
Fabric Attach Authentication
Zero Touch Client
Configuring Fabric Attach
Static NSI Offset
FDB
FDB Contents
How FDB Entries Get Added
How FDB Entries Age Out
FDB Entry Types
Dynamic Entries
Static Entries
Blackhole Entries
Private VLAN Entries
Managing the FDB
Increasing the FDB Table Size
Clearing FDB Entries
Supporting Remote Mirroring
Display FDB Entries
Display FDB Statistics
MAC-Based Security
Managing MAC Address Learning
Managing Egress Flooding
Configuring Egress Flooding
Managing MAC Address Tracking
Identity Management
Identity Management Overview
Identity Information Capture
Identity Names
How Roles Affect Ports
Blacklist and Whitelist Roles
Greylist Roles
User-Defined Roles
Role Precedence and Priority
Role-Based Policy Enforcement
Role-Based VLAN
Group Attributes Support
Role Refresh
Configuring List-Precedence
Configuring Kerberos Snooping
Forced Kerberos Logout
Changing the Role Priority
Displaying Database Entries
Displaying Statistics
SSD-120 Device
IPv4 Unicast Routing
IPv4 Unicast Overview
Router Interfaces
GRE Tunnel
Populating the Routing Tables
Dynamic Routes
Static Routes
Multiple Routes
Relative Route Priorities
IP Route Sharing and ECMP
Compressed Routes
Event Log Messages
Exceptional Scenarios
Extended IPv4 Host Cache
LPM Table Management
ECMP Hardware Table
Configuring Unicast Routing
Configuring Static Routes
Configuring IP Route Sharing
Managing IP Route Sharing
Configuring Route Compression
Viewing IP Routes
Viewing the IP ARP Table
Viewing IP ARP Statistics
Viewing Compressed Routes
Proxy ARP
ARP-Incapable Devices
Proxy ARP Between Subnets
IPv4 Multinetting
Multinetting Topology
ARP
Route Manager
IRDP
Unicast Routing Protocols
IGMP Snooping and IGMP
Multicast Routing Protocols
EAPS, ESRP, and STP
DHCP Server
DHCP Relay
VRRP
Configuring IPv4 Multinetting
IP Multinetting Examples
DHCP/BOOTP Relay
Managing DHCP/BOOTP Relay
DHCP Smart Relay
Configuring UDP Forwarding
IP Broadcast Handling
VLAN Aggregation
VLAN Aggregation Properties
VLAN Aggregation Limitations
VLAN Aggregation Example
IPv6 Multicast
Managing MLD
MLD Snooping
MLD Snooping Filters
Configuring MLD Snooping
Configuring Static MLD
MLD Loopback
Displaying MLD Information
MLD SSM Mapping
SSM Address Range
Handling MLD Reports
SSM Data Forwarding
DNS Request/Response
DNS Timers
DNS Server
Configuring MLD SSM Mapping
IPv6 Unicast Routing
IPv6 Unicast Overview
Router Interfaces
Tunnels
Specifying IPv6 Addresses
Scoped Addresses
Neighbor Discovery Protocol
Managing Neighbor Discovery
DAD Overview
Configure DAD
Clear the DAD Counters
Dynamic Routes
Static Routes
Multiple Routes
Managing IPv6 Unicast Routing
Managing Router Discovery
Managing Tunnels
Create an IPv6-in-IPv4 Tunnel
Create an IPv6-to-IPv4 Tunnel
Delete a Tunnel
Display Tunnel Information
IPv6 ECMP and 32-Way ECMP
DHCPv6 Relay Remote-ID Option
DHCPv6 Client
DHCP Unique Identifier
Configure Route Compression
Hardware Forwarding Behavior
Hardware Tunnel Support
Tunnel Configuration Examples
Host Configurations
IS-IS Overview
Establishing Adjacencies
Point-to-Point Adjacency
Broadcast Adjacency
IS-IS Hierarchy
IS-IS and IP Routing
Summary Addresses
External Connectivity
Authentication
Dynamic Hostname
Route Leaking
Metric Types
IS-IS Restart
IPv4 and IPv6 Topology Modes
Configuring IS-IS
Configuring L1 Routers
Configuring L1/L2 Routers
Configuring L2 Routers
Configuring IS-IS Timers
Configuring Hello Padding
Configuring an Import Policy
Displaying IS-IS Information
Displaying IS-IS Neighbors
Displaying IS-IS Counter Data
Managing IS-IS
Configuring Password Security
Clearing the IS-IS Counters
Managing IP Summary Addresses
Managing VLAN Interfaces
Adding a VLAN Interface
Deleting a VLAN Interface
Managing IS-IS Routers
Adding an IS-IS Router
Disabling an IS-IS Router
Deleting an IS-IS Router
Keychain Manager
Keychain Manager Overview
Layer 2 Protocol Tunneling
Protocol Tunneling
Protocol Filtering
Protocol Filters
L2PT Limitations
Overview of Layer 3 VPN
Overview of BGP/MPLS Network
Multi-protocol BGP Extension
Multiple Forwarding Tables
L3VPN BOOTP Relay
L3VPN Configuration Example
LLDP
Mandatory TLVs
Optional TLVs
LLDP MED Optional TLVs
LLDP Packets
Transmitting LLDP Messages
Receiving LLDP Messages
LLDP Management
Configuring and Managing LLDP
Enabling and Disabling LLDP
Configuring LLDP Timers
Configuring SNMP for LLDP
Port description TLV
System name TLV
System Description TLV
System Capabilities TLV
Management Address TLV
VLAN Name TLV
Port VLAN ID TLV
Port and Protocol VLAN ID TLV
Power Via MDI TLV
Link Aggregation TLV
Maximum frame size TLV
Call Server TLV
File Server TLV
802.1Q Framing TLV
Configuring LLDP MED TLVs
LLDP MED capabilities TLV
LLDP MED Fast-Start Feature
Network policy TLV
Location identification TLV
Extended power-via-MDI TLV
SNMP Traps for LLDP MED
Unconfiguring LLDP
Instant Port Enhancements
Displaying LLDP Information
MPLS
MPLS Overview
How MPLS Works
MPLS Protocol Preference
MPLS Terms and Acronyms
LDP Support
LDP Neighbor Discovery
Advertising Labels
Propagating Labels
Label Advertisement Modes
Label Retention Modes
LSP Control Modes
MPLS Routing
MPLS Layer Details
MPLS Shim Header
MPLS Label Stack
Penultimate Hop Popping
Label Binding
Label Space Partitioning
Matching LSP Next Hops
OSPF Calculated LSP Next Hops
BGP Calculated LSP Next Hops
Layer 2 VPN Support
MPLS Pseudowires
LSP Selection
Layer 2 VPN Domains
MAC Learning
Spanning Tree Protocols
IP Protocol Considerations
H-VPLS Overview
Event Log Messages
SNMP Support
H-VPLS Redundant Edge Network
Fault Tolerant VPLS Operation
Event Log Messages
SNMP Support
VPLS STP Redundancy Overview
Requirements and Limitations
VPLS EAPS Redundancy Overview
Failure Recovery Scenario 1
Failure Recovery Scenario 2
Failure Recovery Scenario 3
RSVP-TE Overview
RSVP Elements
Message Types
Reservation Styles
RSVP Traffic Engineering
RSVP Tunneling
RSVP Objects
ERO Exclude Option
Establishing RSVP-TE LSPs
RSVP-TE Implementation
Explicit Route Path LSPs
Route Recording
LSP Session Attributes
Bandwidth Reservation
Redundant LSPs
Improving LSP Scaling
Propagation of IP TTL
IXP MPLS Enhancements
Configuring MPLS
Moving MPLS From VR to VR
Configuring the MPLS LSR ID
Adding MPLS Support to VLANs
Enabling LDP on the Switch
Creating Static LSPs
Configuring QoS Mappings
Mapping Dot1p to EXP Bits
Restoring LDP Session Timers
Managing the MPLS BFD Client
Displaying the RSVP-TE Paths
Displaying the RSVP-TE LSP
MPLS Configuration Example
Displaying Layer 2 VPN Status
Core 1 Router Configuration
Core 2 Router Configuration
Configuring H-VPLS
Configuring H-VPLS Core Nodes
Configuring Protected VPLS
Configuring RSVP-TE
Creating an RSVP-TE Path
Configuring an Explicit Route
Reserving Bandwidth for MPLS
RSVP-TE Configuration Example
Troubleshooting MPLS
Using LSP Ping
Using LSP Trace
MSDP
MSDP Overview
Supported Platforms
PIM Border Configuration
MSDP Peers
MSDP Default Peers
Peer Authentication
Policy Filters
SA Request Processing
MSDP Mesh-Groups
Anycast RP
SA Cache
Maximum SA Cache Entry Limit
SNMP MIBs
Multicast Routing Overview
Multicast Table Management
IPv4 Multicast Route Table
L3 Hash Table
IP Multicast Group Table
PIM Overview
PIM Edge Mode
PIM Dense Mode
PIM-DM Without State Refresh
PIM-DM with State Refresh
PIM Sparse Mode
PIM Mode Interoperation
PIM Source Specific Multicast
PIM Snooping
PIM Register Policy
PIM DR Priority
PIM ECMP Load Splitting
IPv6 Specific Features
IGMP Overview
IGMP Snooping
IGMP Snooping Filters
Static IGMP
IGMP Loopback
IGMP-SSM Mapping
Configuring IGMP-SSM Mapping
Displaying IGMP-SSM Mappings
IGMP Statistics
Enabling Multicast Forwarding
Configuring PIM
PIM Configuration Examples
PIM-DM Configuration Example
PIM-SM Configuration Example
PIM-SSM Configuration Example
Multicast VLAN Registration
Basic MVR Deployment
Static and Dynamic MVR
Configuring MVR Address Range
MVR Configuration Example
MVR Forwarding
MVR Configurations
MVR with EAPS
MVR with STP
MVR in a VMAN Environment
Looking Up a Multicast Route
Troubleshooting PIM
Multicast Trace Tool
Network Login
Network Login Overview
Multiple Supplicant Support
Campus and ISP Modes
Initial Hitless Failover
Network Login over LAG
Network Login over MLAG
Configuring Network Login
Setting Netlogin Traps
Exclusions and Limitations
Specifying a Destination VLAN
Adding VLANs at a Later Time
Updating VLAN Attributes
Interoperability Requirements
Supplicant Side
Authentication Server Side
Configuring Guest VLANs
Using Guest VLANs
Creating Guest VLANs
Enabling Guest VLANs
Disabling Guest VLANs
Unconfiguring Guest VLANs
Example Scenarios Using NAP
ACLS for Remediation Servers
Web-Based Authentication
Configuring the Base URL
Configuring the Redirect Page
Configuring Proxy Ports
Configuring Session Refresh
Configuring Logout Privilege
Configuring the Login Page
Login Page Contents
General Guidelines
MAC-Based Authentication
Configuring the Port Mode
Configuring Ingress Filtering
FDB Information
VLAN and Port Information
Specifying the Uplink Ports
Fallback VLANs in Policy
RADIUS Netlogin Keep Alive
OAM
CFM
CFM Overview
Ping and Traceroute
Supported Instances for CFM
CFM Groups
Configuring CFM
Creating Maintenance Domains
Creating and Associating MAs
Add a RMEP to MEP Group
Monitoring CFM in EAPS
Displaying MEP Groups
Displaying CFM
CFM Example
Frame-Delay Measurement
Frame-Loss Measurement
Configuring a CFM Segment
Managing a CFM Segment
Clearing CFM Information
Y.1731 MIB Support
TWAMP-Test Protocol
Configuring BFD
Configuring BFD Intervals
Displaying BFD Information
Clearing BFD Information
BFD Hardware Assist
BFD MIB Table Support
BFD Session Up/Down Traps
ONEPolicy
ONEPolicy Overview
Implementing Policy
Captive Portal Redirection
VLAN/VXLAN to Policy Mapping
Policy-Based Mirrors
VCAP Partitioning
ACL Style Policy
Dynamic ACLs
Role-based ACLs
Terms and Definitions
Policy Roles
The Policy Role
Defining a Policy Role
Roles in a Secure Network
Classification Rules
Specifying Storage Type
Forward and Drop
Rule Precedence
Platform Rule Allocation
NetLogin Authentication
Authentication Override
Configuring Policy
Roles
Policy Domains
Platform Configuration
OSPF Overview
OSPF Edge Mode
BFD for OSPF
Link State Database
Database Overflow
Opaque LSAs
Graceful OSPF Restart
Restarting and Helper Mode
Areas
Backbone Area (Area 0.0.0.0)
Stub Areas
Not-So-Stubby-Areas
Normal Area
Virtual Links
Point-to-Point Support
Import Policy
Redistribute Routes into OSPF
Configuring OSPF
OSPF Wait Interval Parameters
OSPF Configuration Example
Configuration for ABR 1
Configuration for IR 1
Displaying OSPF Settings
OSPFv2 Auto-peering
OSPFv3 Overview
OSPFv3 Edge Mode
BFD for OSPFv3
Link State Database
Graceful OSPFv3 Restart
Areas
Stub Areas
Not-So-Stubby-Areas
Normal Area
Virtual Links
Link-Type Support
Import Policy
OSPFv3 Timers
OSPFv3 Authentication
IPsec Authentication
Authentication Trailer
PoE
Extreme Networks PoE Devices
Summary of PoE Features
Power Delivery
Enabling PoE to the Switch
Power Reserve Budget
PD Disconnect Precedence
Port Disconnect or Fault
Port Power Cycling
PoE Usage Threshold
Legacy Devices
PoE Operator Limits
Configuring PoE
enable inline-power
Configuring PoE Port Labels
Power Cycling Connected PDs
Clearing Statistics
Display System PoE Status
Display Port PoE Status
Policy Manager
Creating and Editing Policies
Using the Edit Command
Checking Policies
Refreshing Policies
Applying Policies
Applying ACL Policies
Applying Routing Policies
QoS
QoS Overview
Applications and Types of QoS
Voice Applications
Video Applications
Web Browsing Applications
File Server Applications
Traffic Groups
ACL-Based Traffic Groups
DiffServ-Based Traffic Groups
Port-Based Traffic Groups
VLAN-Based Traffic Groups
Precedence of Traffic Groups
Single-Rate QoS
Dual-rate QoS
Rate Specification Options
Scheduling
Introduction to WRED
Meters
QoS Profiles
Egress Qos Profiles
Class of Service (CoS)
Port Groups
CoS Port Resource
CoS Global Enable Action
Meter and Flood Actions
Meter and Flood Limitations
Configuring QoS
Configuration Summary
Replacement of DSCP on Egress
Replacing a DSCP on Egress
DiffServ Example
Configuring Egress Traffic
Configuring Traffic Groups
Creating and Managing Meters
Creating Meters
Configuring a Meter
Deleting a Meter
RADIUS over TLS
TLS Connection Persistence
Supported Platforms
RADIUS Over TLS CLI Commands
Setting Up FreeRADIUS TLS
IGPs Overview
RIP Versus OSPF and IS-IS
Overview of RIP
Routing Table
Split Horizon
Poison Reverse
Triggered Updates
Route Advertisement of VLANs
Redistribute Routes into RIP
RIP Configuration Example
RIPng
RIPng Overview
RIPng versus OSPFv3 and IS-IS
RIPng Routing
Routing Table
Split Horizon
Poison Reverse
Triggered Updates
RIPng Configuration Example
Routing Policies
Routing Policies Overview
Routing Policy File Syntax
Policy Match Type
Policy Match Conditions
Autonomous System Expressions
Policy Action Statements
Policy Examples
Security Features Overview
Security Mode Overview
Secure Mode
Using Safe Defaults Mode
MAC Security
MAC Locking
MAC Locking Limitations
MAC Locking Functionality
Configuring MAC Locking
Managing MAC Locking
Configuring Limit Learning
Example of Limit Learning
MAC Address Lockdown
Example of Port Movement
Troubleshooting MAC Security
Alternate MAC Address Support
DHCP Server
Configuring the DHCP Server
Displaying DHCP Information
IP Security
Configuring DHCP Snooping
Configuring DHCP Binding
Source IP Lockdown
Configuring ARP Learning
Configuring DHCP Secured ARP
Displaying ARP Information
Gratuitous ARP Protection
ARP Validation
Configuring ARP Validation
Denial of Service Protection
Configuring Trusted Ports
Protocol Anomaly Protection
Flood Rate Limitation
Changing the TACACS+ Server
TACACS+ Configuration Example
Authentication
Accounting
Authentication NMS Realm
Supported RADIUS Attributes
Configuring the RADIUS Client
Session Management Entries
Network Login User Entries
Extreme Networks VSAs
Disconnect Request
NAS Identification
User Session Identification
Disconnect Responses
Change of Authorization
Retry Detection
New Attribute Support
RADIUS Port Bounce
Modifying the RADIUS Schema
Cistron RADIUS
RSA Ace
Steel-Belted Radius
Microsoft IAS
Setting Up Open LDAP
Installing OpenLDAP
Configuring OpenLDAP
Configuring slapd for Startup
Adding New Schemas
Restarting the LDAP Server
LDAP Configuration Example
Hypertext Transfer Protocol
Secure Shell 2
SSH Server Overview
Understanding SSH Server
Standard Key Authentication
User Key-Based Authentication
Enabling SSH2
Viewing SSH2 Information
Sample SSH2 Policies
Diffie-Hellman Overview
Secure Socket Layer
Enabling and Disabling SSL
Displaying SSL Information
Setting Up PKI
PKI Limitations
ExtremeXOS Upgrade Process
Download URL Method
Downloading a New Image
Image Integrity Checking
Hash Verification
Installing a Core Image
Reboot Options
Reboot the Switch
Software Signatures
Image Configuration Overview
View a Configuration
Comparing Configurations
Restore Factory Defaults
Summary of Tasks
Synchronizing Nodes
Upgrading the Bootrom
Viewing Port Statistics
Viewing Port Errors
Port Link-Flap Detection
SNMP Traps
Port Link-Flap Statistics
Viewing VLAN Statistics
Configuring VLAN Statistics
Guidelines and Limitations
Performing Switch Diagnostics
Running Diagnostics
Using ELSM
About ELSM
ELSM Hello Messages
ELSM Port States
Link States
ELSM Link States
ELSM Timers
Configuring ELSM on a Switch
Enabling ELSM
Configure Automatic Restart
Disabling ELSM
Displaying ELSM Information
Clearing ELSM Counters
ELSM Configuration Example
Viewing Fan Information
System Temperature Output
SummitStack
Target Configuration
Severity
Configuring Severity Level
Components and Conditions
Matching Expressions
Matching Parameters
Formatting Event Messages
Displaying Event Logs
Log Buffer Threshold Alert
Uploading Event Logs
Displaying Debug Information
Logging Configuration Changes
Introduction
HTTP Client Interface
Configuring XML Notification
Displaying XML Notification
Configuring Log Target in EMS
Using sFlow
Configuring sFlow
Configuring the Local Agent
Polling Interval
Global Sampling Rate
Per Port Sampling Rate
Maximum CPU Sample Limit
Unconfiguring sFlow
sFlow Configuration Example
Displaying sFlow Information
Using RMON
About RMON
RMON Agent
Management Workstation
Statistics
Events
trapDestTable
Extreme-RtStats-MIB
Event Actions
Display RMON Information
SMON
Monitoring CPU Utilization
Disabling CPU Monitoring
Enable CPU Monitoring
STP
Default Port Path Cost
Bridge Priority
Port Priority
Edge Port Behavior
Restricted Role
Loop Protect
Loop Protect Port Modes
STP Filter Configuration
Backup Root
Multisource Detection
Span Tree Domains
Member VLANs
carrier VLAN
Protected VLAN
Specifying the Carrier VLAN
STPD Modes
Encapsulation Modes
STPD Identifier
STP States
Binding Ports
Manually Binding Ports
Automatically Binding Ports
Rapid Root Failover
STP Configurations
Basic STP Configuration
Multiple STPDs on a Port
VLANs Spanning Multiple STPDs
EMISTP Deployment Constraints
Per VLAN Spanning Tree
STPD VLAN Mapping
Native VLAN
Rapid Spanning Tree Protocol
RSTP Concepts
Port Roles
Link Types
Configuring Link Types
Configuring Edge Safeguard
Configuring Auto Edge
RSTP Timers
RSTP Operation
Root Port Rapid Behavior
Receiving Bridge Behavior
Rapid Reconvergence
MSTP Concepts
MSTP Regions
Unconfiguring an MSTP Region
Configuring the CIST
CIST root bridge
CIST regional root bridge
CIST Root Port
Enabling the CIST
MSTI Regional Root Bridge
MSTI Root Port
Enabling the MSTI
Boundary Ports
MSTP Port Roles
MSTP Port States
MSTP Link Types
MSTP Edge Safeguard
MSTP Timers
MSTP Hop Counts
MSTP Operation
STP and Network Login
STP and MLAG
STP Rules and Restrictions
Configuring STP on the Switch
STP FDB Flush Criteria
Displaying STP Settings
STP Configuration Examples
EMISTP Configuration Example
MSTP Configuration Example
EXTREME ACL MIB
CTRON Alias MIB
EXTREME-CFGMGMT-MIB
ENTERASYS-MIRROR-CONFIG-MIB
ENTERASYS-MULTI-AUTH-MIB
ENTERASYS-POLICY-PROFILE-MIB
ENTERASYS SYSLOG MIB
EXTREME-AUTOPROVISION-MIB
EXTREME-CFM-MIB
EXTREME-CLEARFLOW-MIB
EXTREME-EAPS-MIB
EXTREME-EDP-MIB
EXTREME-ENTITY-MIB
EXTREME-ERPS-MIB
EXTREME-ESRP-MIB
EXTREME-FDB-MIB
EXTREME-MAC-AUTH-MIB
EXTREME MLAG MIB
EXTREME-MPLS-MIB
EXTREME-MPLS-TE-MIB
EXTREME-OSPF-MIB
EXTREME-PoE-MIB
EXTREME-PORT-MIB
Pseudowire LSP Sharing MIB
EXTREME-QOS-MIB
EXTREME-PVLAN-MIB
EXTREME-SNMPv3-MIB
EXTREME-STP-EXTENSIONS-MIB
EXTREME-STPNOTIFICATIONS-MIB
EXTREME-SYSTEM-MIB
EXTREME-V2TRAP-MIB
EXTREME-VLAN-MIB
EXTREME-VM-MIB
MIB Support Details
ETMONSERVICEABILITYTRAP
IEEE 802.1AB (LLDP-MIB)
IEEE 802.1AG (CFM MIB)
IEEE8021-PAE-MIB
IEEE8021X-EXTENSIONS-MIB
SNMPv3 MIBs
RFC 1213 (MIB-II)
RFC 4363 (P-BRIDGE-MIB)
RFC 4363 (Q-BRIDGE-MIB)
RFC 1724 (RIPv2-MIB)
RFC 1850 (OSPF-MIB)
RFC 2233 (IF-MIB)
RFC 2613 (SMON)
RFC 2665 (EtherLike-MIB)
RFC 2668 (MAU-MIB)
RFC 2787 (VRRP-MIB)
RFC-3433 (Entity Sensor MIB)
RFC 3621 (PoE-MIB)
RFC 4022 (TCP-MIB)
RFC 4087 (TUNNEL-MIB)
RFC 4113 (UDP-MIB)
RFC-4133 (ENTITY MIB)
RFC 4292 (IP-FORWARD-MIB)
RFC 4293 (IP-MIB)
RFC 5601 (PW-STD-MIB)
RFC 5602 (PW-MPLS-STD-MIB)
RFC 5603 (PW-ENET-STD-MIB)
RFC 5643
RFC 6933 (ENTITY-MIB)
Troubleshooting Checklists
Layer 1
Layer 2
Layer 3
LEDs
Node Prompt—SummitStack Only
Command Prompt
Port Configuration
VLANs
STP
ESRP
VRRP
About Standalone ELRP
Non-periodic ELRP Requests
Periodic ELRP Requests
ELRP Egress Port Disable
Exclude Port List
ELRP with Dynamic VLANs
Hardware-Assisted ELRP
Configuring Standalone ELRP
Configuring Periodic Requests
Configuring Exclude Port List
Debug Mode
Saving Debug Information
Managing Debug Files
TOP Command
TFTP Server Requirements
System Odometer
Monitored Components
Recorded Statistics
Temperature Operating Range
Proactive Tech Support
Locating a Collector
Data Collection
Universal Port
Profile Types
Static Profiles
Dynamic Profiles
Dynamic Profile Trigger Types
Device Triggers
User Authentication Triggers
Time Triggers
Obtaining Profiles
Profile Rules
Universal Port Variables
Device-Detect Configurations
Time-of-Day Configurations
EMS-Event Configurations
Editing an Existing Profile
Configuring a Timer Trigger
Creating an EMS Event Filter
Unconfiguring a Timer
Displaying a Profile
Displaying Timers
Displaying Profile History
Deleting a Profile
Deleting a Timer
Deleting an EMS Event Trigger
Sample MAC Tracking Profile
MAC Tracking EMS Log Message
Policy File Configuration
Console Logs
Sample Static Profiles
Sample Event Profile
Using CLI Scripting
Setting Up Scripts
Creating Scripts
Creating a Script File
ExtremeXOS Shell RC Script
Python Scripting
Python Scripting Examples
Using Script Variables
Creating Variables
Using Operators
Using Built-In Functions
Nesting Scripts
Executing Scripts
Execute a Script File
Configuring Error Handling
Aborting a Script
Viewing CLI Scripting Status
Controlling CLI Script Output
CLI Scripting Examples
Virtual Routers
Overview of Virtual Routers
Types of Virtual Routers
System Virtual Routers
User Virtual Routers
VRFs
Local-Only Virtual Routers
VR Configuration Context
Managing Virtual Routers
Creating and Deleting VRFs
Enabling and Disabling VRFs
Changing the VR Context
Configuring a VPN ID
Configuring Route Targets
VLANs
VLANs Overview
Benefits
Virtual Routers and VLANs
Types of VLANs
Port-Based VLANs
Tagged VLANs
Defining Protocol Filters
Deleting a Protocol Filter
Default VLAN
VLAN Names
VLAN Configuration Overview
Creating and Deleting VLANs
Managing a VLAN IP Address
Configuring a VLAN Tag
Renaming a VLAN
Enabling and Disabling VLANs
VLAN Configuration Examples
IP and MAC Anycast
Displaying VLAN Information
PVLAN Overview
VLAN Translation in a PVLAN
VLAN Isolation
PVLAN Components
Layer 3 Communications
PVLAN Limitations
Configuring PVLANs
Creating PVLANs
Delete PVLANs
Remove a VLAN from a PVLAN
Displaying PVLAN Information
Displaying PVLAN FDB Entries
PVLAN Configuration Example 1
PVLAN Configuration Example 2
VLAN Translation
VLAN Translation Behavior
Unicast Traffic
Broadcast Behavior
Multicast Behavior
VLAN Translation Limitations
Configuring Translation VLANs
Basic VLAN Translation
Port-Specific VLAN Tag
Port-Specific Tags in L2VPN
VMAN (PBN)
VMAN Overview
Customer Network Ports
Customer Edge Ports
CVID Translation
CVID Egress Filtering
ACL Support
Secondary Ethertype Support
QoS Support
Egress Queue Selection
VMAN Double Tag Support
Configuration
Configuring VMANs (PBNs)
Configuring VMAN Options
Displaying VMAN Information
VMAN CEP Example
VRRP
VRRP Overview
VRRP Master Election
VRRP Master Preemption
VRRP Tracking
VRRP Tracking Mode
VRRP VLAN Tracking
VRRP Route Table Tracking
VRRP Ping Tracking
VRRP Address Support for IPv4
VRRP Address Support for IPv6
NTP VRRP Virtual IP support
VRRP Active-Active
VRRP Fabric Routing
Fabric Routing Functionality
Enabling Fabric Routing Mode
Fabric Routing Limitations
VRRP and Hitless Failover
VRRP Host Mobility
VRRP Grouping Limitations
VRRP Grouping Description
Configuring VRRP
Configuring Master Preemption
Configuring the Accept Mode
Configuring VRRP Tracking
Configuring the Tracking Mode
Configuring Host Mobility
Configuring VRRP Groups
Managing VRRP
Clearing VRRP Counters
Displaying VRRP Information
VRRP Configuration Examples
Simple VRRP Network Examples
VRRP Load Sharing Example
VRRP Tracking
VXLAN
VXLAN Overview
Overlay Routing
Routing Traffic into Tunnels
Routing Traffic from Tunnels
Time to Live (TTL) Processing
Unicast and Multicast VXLAN
Virtual Network Flood Modes
Flood Mode Standard
Flood Mode Explicit
Flood Mode Multicast
Assisted Replication
Assisted Replication Overview
Assisted Replication Benefits
OSPFv2 VXLAN Extensions
Dynamic Virtual Networks
Edge Automation
VXLAN Learning
Dynamic Learning
Load Balancing
Redundant Access
Statistics
Configuring VXLAN
Configuring Local Endpoints
Configuring Edge Automation
To enable the transmission of
SNMP
traps for identity management low memory conditions, use the following command:
enable snmp traps identity-management
To disable SNMP traps for identity management, use the following command:
disable snmp traps identity-management
Section contents:
