Built in functions allow you to manipulate and evaluate the variables inside your script and the script output. Built-In Functions shows the built-in functions. Supported TCL Functions shows the built-in Tool Command Language (TCL) functions.
ExtremeXOS uses TCL version 8.5.14.| Syntax | Function |
| $MATCH(string 1, string 2) |
Compares the two strings string 1 and string 2. Returns 0 if string1 matches string2. It returns -1,0, or 1, depending on whether string1 is less than, equal to, or greater than string2. |
| $READ(prompt) | Displays a prompt for user input and accepts input until the user presses [Enter] or the session times out. Replace prompt with the prompt to display to the user. |
| $TCL(function args) | Calls a TCL built-in function (see Supported TCL Functions). Note that the software does not support the simultaneous operation of multiple TCL functions. For more information on TCL functions, go to http://www.tcl.tk/man/tcl8.3/TclCmd/contents.htm. |
| $UPPERCASE(string) | Returns the string uppercased. |
| $VAREXISTS(varname) | Returns zero if the specified variable does not exist. Returns non-zero if the specified variable does exist. |
| Function | Function Type | Description |
| after | System related | Execute a command after a time delay. |
| binary | String handling | Insert and extract fields from binary strings. |
| clock | System related | Obtain and manipulate time. |
| concat | List handling | Join lists together. |
| expr | Math | Evaluate an expression. |
| join | List handling | Create a string by joining list elements together. |
| lindex | List handling | Retrieve an element from a list. |
| linsert | List handling | Insert elements into a list. |
| list | List handling | Create a list. |
| llength | List handling | Count the number of elements in a list. |
| lrange | List handling | Return one or more adjacent elements from a list. |
| lreplace | List handling | Replace elements in a list with new elements. |
| lsearch | List handling | See if a list contains a particular element. |
| lsort | List handling | Sort the elements of a list. |
| regexp | String handling | Match a regular expression against a string. |
| regsub | String handling | Perform substitutions based on regular expression pattern matching. |
| re_syntax | String handling | Syntax of TCL regular expressions. |
| split | List handling | Split a string into a proper TCL list. |
| string | String handling | Manipulate strings. |
For examples of scripts that use TCL functions, see CLI Scripting Examples.
