This feature adds support for the EXOS ACL match criteria "cvid." It provides the ability to specify access-lists that filter on the inner-VLAN-id field of a double tagged packet, the customer VLAN id field of a single tagged packet entering a VMAN UNI/CEP port, or the port-cvid inserted into an untagged packet entering a VMAN UNI port. You can use this feature to perform service-level, or customer-level (cvid) rate-limiting and accounting.
You can utilize this match criteria in the following scenarios:
create vman vm1 tag 100 config vman vm1 add port 1 cep cvid 7 translate 8 config vman vm1 add port 2 tagNow consider the following ACL policy applied to "access" port 1:
test.pol:
entry one {
if {
cvid 7;
} then {
count count7;
entry two {
if {
cvid 8;
} then {
count count8;
config access-list test port 1
config access-list test port 1 egress
This
results in "count8" incrementing for ingress, and "count7" incrementing on
egress.Here is another example policy:
entry one {
if{
cvid 7;
vlan-id 100; #SVID
} then {
count foo;
And here's an example that allow you to perform service-level, or customer-level (cvid) rate-limiting and accounting:
doubletag.pol:
entry customer1 {
if{
cvid 8;
} then{
count cust1;
config vman vm1 add port 21
config vman vm1 add port 22 tag
config access-list doubletag port 21
config access-list doubletag port 21 egress
The CVID ACL match criteria support has the following limitations:
CVID ACl match criteria is supported on all platforms.
