By default, Node Alias is disabled on all ports.
Node Alias should be separately enabled/disabled on a LAG ports.enable nodealias ports [port_list | all]
disable nodealias ports [port_list | all]
By default, Node Alias is enabled to capture all of the following supported protocols: IPv4, IPv6, OSPF, BGP, VRRP, DHCPS, DHCPC, BOOTPS, BOOTPC, UDP, BPDU, LLMNR, SSDP, and mDNS.enable nodealias protocol [protocol_name | all]
disable nodealias protocol [protocol_name | any]
To modify the per-port maximum number of alias entries in the Node Alias database, use the following command:
configure nodealias ports [port_list |all] maxentries entries
To show Node Alias information, use the following commands:
show nodealias
show nodealias ports {port_list| all}
show nodealias mac mac_address {protocol protocol_name | ports [port_list | all]}
show nodealias ip ip_address
show nodealias protocol protocol_name
To clear node alias entries out of the Node Alias feature database by specified port(s) or alias ID, use the following command:
clear nodealias { ports [port_list | all] | alias-id alias_id }
