The following tables, groups, and variables are supported in this MIB.
| Table/Group | Supported Variables | Comments |
| extremeTargetAddrExtTable | extremeTargetAddrExtIgnoreMPModel | The value of the snmpTargetParamsMPModel object in the snmpTargetParamsTable is ignored while determining the version of the trap/notification to be sent. When a trap-receiver is created through the CLI command 'configure snmp add trapreceiver ....', the value of this object is set to TRUE for the corresponding entry in this table. |
| extremeTargetAddrExtStandardMode | When this object is set to TRUE, the management target is treated as a 'standard mode' one, in that any Extreme Networks specific extra varbindspresent in a standards-based trap/notification is not sent to this management target. Only the varbinds defined in the standard are sent. | |
| extremeTargetAddrExtTrapSrcIp | This object contains the source IP address from which traps have to be sent out. If this object is assigned an IP address that does not belong to the switch, an error is thrown. | |
| extremeTargetAddrExtVrName | This object contains the VR name through which the SNMP Traps are being sent out. | |
| extremeUsmAesCfb192Protocol | Supported from ExtremeXOS 12.3 | |
| extremeUsmAesCfb256Protocol | Supported from ExtremeXOS 12.3 |
