For added resiliency and redundancy, the VPEX architecture allows you to form an extended bridge using multiple controlling bridges (CBs).
When using MLAG, you must run LACP on the CB MLAG cascade ports.
With an MLAG/Extended Edge Switching topology, enabling policy and using policy features does not work with the ONEPolicy default resource profile. Use the profile-modifier feature to free up ACL resources from any specific policy profile (see Platform Rule Allocation).
Extended Edge Switching Auto-configuration (see Configuring Extended Edge Switching Topology with Partial Automation (Auto-configuration)) uses values within the range of 5100 to 5164 to configure an MLAG port ID. It is recommended that you do not use values within this range when configuring MLAG port IDs manually, since the MLAG port might be unconfigured by auto-configuration when auto-configuration finds the MLAG port ID has already been used.
With redundant CBs attached to each BPE, the associated extended port configuration must be identical on each controlling bridge. To reduce the configuration complexity and to minimize the risk of inconsistency, you can use orchestration mode so that any configuration commands are now checkpointed to the MLAG peer switch. Before entering orchestration mode, ensure that any configuration parameters (connecting ports for the BPEs, VLAN names, numbers etc.) are the same for both CBs.
(orchestration bottom) X670G2-48x-4q.4 #
To enter orchestration mode, use the following command:
start orchestration mlag peer_name
To exit orchestration mode, use the following command:
stop {orchestration}
